I have connected my Quest VR to my PC via Side Quest and Riftcat. The headset and the controllers are tracking. The area highlights with the controllers but I am unable to activate the highlighted area. I am attempting to play Boneworks. Any suggestions?
If you are trying to hook up like link cable, you don't use side quest or Riftcat.. If you are using Riftcat, that is for wireless make sure your Quest is in dev mode. download Vridge from sidequest If you are trying to run it via Oculus link, you need a USB 3 cable.I think having sidequest open disables link.
Gigabyte AB350 Ryzen 2700x, 32gb ddr 4 3200, 2080ti. HP Reverb G2, Index controllers, Quest 1 and 2x Quest 2. 65" 3DTV HD3D DLP projector.
I am connected with a USB 3 cable and in developer mode. I go into unknown resources on the headset and it states to download Riftcat. I do this via Side Quest. I next choose a game and my controller randomly works even though they are connected.
