Showing results forย
Search instead forย
Did you mean:ย
DIY Extension Cord for Rift
SapowiTz
Hi all
Just wanted to share a little life-hack if you are using extension cords for your rift
I bought a 10 foot HDMI and a 10 foot USB 3.0 cable for extending my Rift, but the cables continued curling up all the time in my play area!
So I tied em up using Plastic Wrap. Very effective!
Happy new year! ๐Ÿ™‚
5 REPLIES 5
elboffor
Level 12
I just used black electrical tape every few inches.  Also both the female used and hdmi are taped together. Looks good and work good too.
This is my forum signature.
SapowiTz
Also thought of that, but my electrical tape is "gone bad" so it sticks on both sides now :wink:
elboffor
Level 12
Lmao
In that case I really commend a black marker and a lot of time. Cos your extention looks funky.
Or carry out  the theme and wrap you full rift cord with it also ๐Ÿ˜‰
ratsflif
I used some black zip ties about every 12 inches.  Works fine for me.
elboffor
Level 12
If you measured 12 inches using a part of your anatomy and used 16 zip ties for a 3 foot extention, then you may need to invest in a ruler to avoid misrepresentation claims in the future ๐Ÿ˜‰
