10-14-2014 11:13 AM
10-14-2014 11:41 AM
"TheAsimovInitiative" wrote:
Any thoughts on this? Currently the occulus needs a regular AC power connection. But why is this really? Can it be easily emulated with usb?.
10-14-2014 11:47 AM
10-14-2014 11:48 AM
It... already is powered by USB...? Power adapter is 100% optional.
10-14-2014 11:49 AM
"jo282" wrote:
anyway I have a gaming laptop (780m), and I can tell you you're not rifting without an AC connection. On a gaming laptop, gpu and cpu are throttled on battery and framerates gets really bad.
10-14-2014 11:52 AM
If you change your performance profile to High Performance, you will not be gpu or CPU throttled without the ac connection. You'll probably get 2 or so hours of gaming before it's dead.
10-14-2014 11:53 AM
10-14-2014 11:56 AM
Yeah you can avoid that in settings. My idea is for this is to get a early protable experience. Batteries can always be added. I mean look at those batteries for 1kw motors for electric bikes.
10-14-2014 12:01 PM
He could avoid that, unless the issue is that his battery doesn't output enough juice to power his 780m. Strap a gasoline generator to your back? 😛
