HMD flashing orange light
Solsland
Hi all, (yet) another issue that you might be able to help me with.
Turn PC on, Rift light flashing orange and not starting...
Have disconnected, restarted machine, nothing except an orange flashing light.
As is usual, this has happened when a friend has come round to experience the rift....
5 REPLIES 5
Greyman
Level 9
Open OH and click on the cog in the top right.  Then select settings and look at the devices tab.  Against the image of the Rift, see if the light is green and if not what does the message say?
i had something apparently similar and the message was something about HDMI not being connected so I just carefully unplugged the HDMI cable and then plugged it back in again.  The cable had been properly seated and I had power-cycled several times, but I suspect that my 970 was probably getting confused.
If it isn't the same issue, just let us know what the status message says.
good luck.
Solsland
That solved it, thanks
Greyman
Level 9
Glad I could help 🙂
xxdylanbrownxx
good luck.
what is oh
I believe they meant "Oculus Home." Or, more appropriately, the Oculus desktop App.
