HP Reverb second impression thread. (Revision 2)
Techy111
Volunteer Moderator
Volunteer Moderator
Ok HP have finally started selling the Reverb again after the messy first release. I returned the 1st with issues and received my version 2 model yesterday. Setup is plug and play as you'd expect with a WMR. I did have an issue for an hour or so where I was stuck in 3dof but after tinkering I found the error (user) and was back in 6dof. The cable is still heavy and a tad cumbersome but due to a new included clip, the cable attachment will not come apart now.
Now for the good bits, the resolution ohhh the resolution!!! I am so glad I have my Reverb again for simming. Sod the controllers I don't use them. But in DCS FSX P3D and our Flyinside simulator, the clarity is what I've always wished and hoped for.
Yes I think it does need a 2080ti to get the full benefit of this headset but that's a personal opinion and yes it's a tad pricey but did I mention the resolution?
If you are into sit down experiences or simming then this is a must have HMD, it really does blow everything out of the water (until we hear about the cosmos)
I think the sound is on par with the CV1 through the Reverbs headphones but defo not as comfortable but they are bearable.
Visuals = 10/10
Comfort = 7.5/10
Build quality = 8.5/10
Value = 9/10
Recommendations = 9.5/10
Simmers it's a no brainer, go buy.
77 REPLIES 77
TomCgcmfc
Level 14
Good idea to start a 2nd release thread mate.  Thanks.
i9 9900k, rtx3090, 32 Gb ram, 1tb ssd, 4tb hdd. xi hero wifi mb, Corsair 1000w. Rift cv1, Quest 1, Vive Pro.
Wildt
Level 12
Unless they've redesigned the earphones, I'm gonna have to disagree about their sound quality compared to the CV1s.
And I don't know if you've assimilated the lousy ergonimics of the controllers into the comfort factor or not - but imo they are pretty awful overall.
WMR: HP Reverb
Techy111
Volunteer Moderator
Volunteer Moderator
As I said above mate I don't use the controllers but it's my opinion only re the sound, I don't have that good of hearing after 9 years in the forces so i could be way off  😄
RuneSR2
Level 16
Had this weird dream where most boardies in here suddenly used HMDs from HTC, Valve and HP. Yeah, really weird, my mind goes crazy when I sleep  😄  o:)
[Admitted, this was my - maybe slightly misguided - attempt to make a funny post]
Intel i7 7700K (4.5 GHz); MSI GeForce GTX 1080 8GB Gaming X (oc 2100 MHz gpu boost, 11 GHz mem speed); 16GB Corsair Vengeance DDR4 3200 MHz; MSI Z270I Gaming Pro Carbon AC (VR-Ready) mainboard; Samsung 961 Evo M.2 SSD 128GB (for OS) + Samsung EVO 860 4TB SSD (for games) + Toshiba P300 High-Performance HDD 3TB (for games); Win10 OS; Valve Index and Oculus Rift CV1, the latter nearly always using super sampling 2.0.
"Ask not what VR can do for you – ask what you can do for VR"
Techy111
Volunteer Moderator
Volunteer Moderator
The Reverb will work beside my Rift and Go lol
RuneSR2
Level 16
I also have my CV1 in case someone angrily says to me "you don't belong here"  o:)  😄
Actually I've paid more than 1K for my Oculus software - that's gotta count for something too.
And now to Lone Echo on the Reverb - I wonder if it's possible with the controllers? ... I guess some WMR dudes must have tried it...
RedRizla
Level 16
Do you have the CV1 plugged in at the same time as the Reverb?
Techy111
Volunteer Moderator
Volunteer Moderator
No mate not thought of trying that but will tonight.
RedRizla
Level 16
Go careful -I got a blank screen on my 2D monitor when I tried that with CV1 and Rift S when I had it. I had to do 5 cold reboots to get my 2D computer screen back after doing it.
