01-30-2016 07:20 PM
02-03-2016 09:24 AM
02-03-2016 09:36 AM
"crim3" wrote:"StreetPreacher" wrote:Very low power consumption is one of the benefits of OLED technology.
And how much power does the Rift draw through the USB ports? It must take a fair bit of juice to light up those two HiRes OLED panels?
02-03-2016 12:13 PM
02-03-2016 01:58 PM
02-03-2016 11:16 PM
02-03-2016 11:43 PM
02-04-2016 01:14 AM
02-04-2016 01:48 AM
"KekoaKalani" wrote:
Also be carefull with this, because if you get the 980ti, then the additional pcie slot is no longer useable cause the card will cover the second slot once its added.
so if your usb's arent up to spec, then you cannot add the usb card to it.
If you dont get the 980ti then no worries.
02-04-2016 08:31 AM
"Vega55" wrote:
and 3d movies and then eventually building my own desktop rig.
Is this plan then born dead?
02-04-2016 08:37 AM
"CaptainDangerous" wrote:
Pics from a reddit user. http://imgur.com/gallery/4qAzw/comment/574215321/1?lr=0
