Half Dome 2 Info Page
Shadowmask72
Level 15
TL;DR: It’s been a little over a year since we first unveiled Half Dome—a VR headset prototype that combined mechanical varifocal displays with a wider field of view than the original Rift for improved visual immersion. Since then, an interdisciplinary team at Facebook Reality Labs (FRL) has continued pushing the limits of what’s technologically feasible to move beyond an early “proof of concept.” Today, we’re sharing some exciting updates to the Half Dome prototype that explore a new direction for varifocal and improve both physical and visual comfort—including a new electronic version of Half Dome with no moving parts.
Today at OC6, Facebook Reality Lab Chief Scientist Michael Abrash shared his vision for a virtual collaborative workspace—a space that you would be able to configure any way you wanted, with monitor-quality virtual screens, holograms, and whiteboards. It would give you the ability to interact with real surroundings and use a keyboard and mouse, to share the virtual space with other people, and to manipulate both real and virtual objects with your hands, complete with haptic feedback.
To deliver on that vision, we’d need to solve some considerable challenges. To get virtual monitors at visual parity with real-world monitors, Abrash notes, we’d need high resolution and good image quality—both of which would require very high-resolution displays and much improved optics. We’d want clear, comfortable vision within arm’s length, and we’d need a wider field of view, so that everyone in a meeting could see everyone else—a must for social presence and effective collaboration in VR.
And since we’re talking about technology that could revolutionize how we work, we’d need great ergonomics. To make it comfortable to be in VR for hours at a time, all of the necessary components need to be compact and power-efficient.
At OC6, Abrash shared some of the progress FRL has made on inventing the future in optics, including following up on varifocal and the Half Dome prototype, originally unveiled at F8 2018. That prototype headset was the result of several years of research and iterating on advanced display systems. Today, we pulled back the curtain on what’s next.
Half Dome (left) combined mechanical varifocal displays with a wider field of view for improved visual immersion. FRL’s new VR prototypes, Half Dome 2 (middle) and Half Dome 3 (right), are targeted at ergonomics and comfort, both visual and physical.
Half Dome: A More Immersive and Visually Comfortable Display
Half Dome was our first prototype to achieve two key milestones. First, using Fresnel lenses, it supports a 140° field of view. Second, by physically moving the screens based on eye tracking, it ensures that the image remains sharp, even when inspecting close objects. This was our first step toward more immersive and visually comfortable VR displays in the lab.
Today, we’re sharing a new varifocal concept prototype, Half Dome 2, built by our Display Systems Research team, working closely with several other teams across FRL.
Half Dome 2: Towards a More Comfortable, Compact Display
While the original Half Dome prototype was a proof of concept that prioritized visual immersion, the Half Dome 2 prototype is targeted primarily at ergonomics and comfort, both visual and physical. It’s both substantially smaller and lighter than the original Half Dome prototype, because it manages to fold the optical path into a very small volume.
Productivity demands not just visual comfort but also ergonomic comfort. The Half Dome 2 prototype folds the optical path into a small volume, reducing the size and weight of the headset by 200 grams.
Overall, we’ve been able to improve the form factor substantially and reduce weight by a full 200 grams over Half Dome 1. While the field of view for Half Dome 2 is narrower than its predecessor, it’s still 20% wider than Oculus Quest.
The varifocal hardware has also been considerably improved. Let’s take a look inside.
Mechanical varifocal module of Half Dome 2 (left) and original Half Dome prototype (right).
The mechanical varifocal system relies on voice coil actuators and flexure hinge arrays. These reduce friction, minimize noise, and maximize the lifetime of the headset’s moving mechanical parts—all improvements on the original Half Dome prototype.
Half Dome 3: More Compact with Electronic Varifocal
We also unveiled an electronic version in the Half Dome series of prototypes—one that replaces all of the moving mechanical parts with a new type of liquid crystal lens made from a thin, alternating stack of two flat optical elements: polarization-dependent lenses (PDLs) and switchable half-wave plates.
The electronic varifocal system of Half Dome 3 (left) is smaller in size than the mechanical system of the original Half Dome prototype (right), reducing overall headset dimensions even further.
PDLs are special because their focal length changes based on their polarization state. By changing the voltage applied to the switchable plates, we can toggle between the two focal lengths. This could make for a great set of digital bifocals, but it doesn’t necessarily make for comfortable VR. By stacking a series of PDLs and switchable half-wave plates on top of each other, we’re able to achieve smooth varifocal that lets you comfortably and seamlessly adjust your focus in the headset.
Let’s take a look at a prototype module to understand how this works. The image on the right was recorded through the electronic varifocal module shown above—this is a real camera shot of a dinosaur figure in front of a plant. The dinosaur is nearer to the camera. On the left, we indicate that a lens is “on” by highlighting it in orange; when it’s off, its focus shifts to the far object (in this case, the plant).
As you can see, the liquid crystal lenses shift focus between different depths. To achieve smooth varifocal, we address the full stack of liquid crystal lenses, with each additional pair doubling the number of focal planes. In the example above, six liquid crystal lenses are driven to sweep through 64 focal planes, and you can see the focal depth smoothly changing at the right as we cycle through different sets of lens states.
Half Dome 3 replaces the moving mechanical parts of the original Half Dome prototype with liquid crystal lenses, eliminating noise, vibration, and mechanical complexity, and improving ergonomics.
In addition to having no moving parts, this approach allows for a significantly better form factor compared to its predecessors in the Half Dome series of prototype. When we integrate the electronic module into a complete prototype headset, it defines a new state of the art for VR ergonomics.
This is still very much research today, but here’s our standard demo, viewed in an early Half Dome 3 prototype.
As you can see, without varifocal, the tape gets blurry up close, but the electronic approach is able to replicate the smooth varifocal experience of mechanical systems at all depths—a promising sign for the future.
This latest update to the Half Dome series of prototypes digitally switches between a large number of focal states—so many, in fact, that it appears continuous, just like the mechanical varifocal displays. For the first time, we’ve achieved a more ergonomic design with a significant reduction in weight. That opens the door to a future where we can be in VR for hours at a time, collaborating with others using any number of digital whiteboards spread throughout our ideal virtual workspace. While we’re still developing the Half Dome series of prototypes at FRL, we’re excited to see where our varifocal research takes us next.
System Specs: ASUS NVIDIA RTX 3090 TUF GAMING OC 24GB , i9 9900K CPU, 16 GB DDR 4 RAM, Win 10 64 Bit OS.
15 REPLIES 15
Spuzzum
Level 9
It would be nice if the varifocal could be set for glasses wearers to eliminate the need for glasses while in vr.
Shadowmask72
Level 15
Now this is some pretty sexy stuff to get excited about. This VR gimmick is getting more interesting by the day.
nalex66
Volunteer Moderator
Volunteer Moderator
That Half Dome 3 prototype looks sexy as hell. ❤️
i7 5820K @ 4.25GHz | RTX 3080 Ti FTW3 | Gigabyte GA-X99-UD4 | Corsair DDR4 3000 32GB | Corsair HX 750W
lensmandave
Level 9
Re the VariFocal stuff...am I missing something here? We have a flat screen in the headset which is either in or out of focus according to the optics we view it through. How can any change in the focus affect just part of the flat image ( like the example in the video above) ?
Intel Core i7 6700K @ 4.5GHz. Asus-Z170-PRO MB - Nvidia RTX 3080 ti - 16GB DDR4 2666MHZ HYPERX SAVAGE.
DaftnDirect
Volunteer Moderator
Volunteer Moderator
Yep, with the headset reducing in size like that, it's unlikely glasses would be accommodated well... maybe even looking tight for purpose made prescription lenses. Fascinating stuff though.
Intel 5820K OC@4Ghz, Titan X (Maxwell), 32GB Corsair Vengeance DDR4, ASRock X99 Taichi, Samsung 500Gb 960 Evo M.2, Corsair H100i v2 Cooler, Inateck KTU3FR-4P USB 3 card, Windows 10 Pro v21H2 (19044.1706)
nalex66
Volunteer Moderator
Volunteer Moderator
I think the blurring is a rendering effect, but the shift in focal distance makes you adjust your eye’s focal distance to match what’s on-screen. This could work really well in conjunction with eye tracking; without it, the effect might be weird if you look at anything other than what’s supposed to be in focus.
Anonymous
Not applicable
I'm pretty sure that this is part of the plan, they wouldn't be working on this if a large percentage of people were unable to use the headset due to having non 20/20 vision.
Spuzzum
Level 9
They'd need a way to calibrate it though, but that shouldn't be too hard to implement.
hoppingbunny123
Level 8
i drew up a simple sketch of how to made a similar design, probably cheaper, just more gawdy. but it would be light too since its just mirrors mostly, mirror and space. see attached picture.
what this does is it starts with a source that sends a image to a plane mirror that reflects the light to other plane mirrors that eventually gets sent to the one plane mirror that = the source, then that plane mirror the source gets sent through a bunch of angled plane mirrors to eventually be seen by the eye.
the trick is the mirrors that have the video from the source have a on off shutter like camera shutter that hides the image from the source or shows it. this keeps the image distinguishable from the other source images. the shutter is the only moving part. in the picture the shutter is where i scribbled its on the bottom of the picture. the source is where the green star is.
this would keep the screen from being flat on the eyes too.
edit i had the green stars in the wrong spot for the left eye so i fixed that and re-uploaded the picture.
edit 2. i drew a ling red line for both the left and right eye from one source to the eye so theres no guessing on the path. i re-uploaded the edited picture.
edit 3. after thinking some more, the source mirror might have to tilt to send the image from the shutter mirror in a straight line.
