How to get rid of background grid when viewing Netflix?
Kerrith
How to get rid of background grid when viewing Netflix? When I'm viewing Netflix 4k specials, say of elephants or waterfalls, the 360 grid stays in the background.
3 REPLIES 3
Kerrith
Re: "
  • Updated Stationary Guardian visuals to remove the grid." How do I remove the grid?
  • "Updated Stationary Guardian visuals to remove the grid." How do I remove the grid?
  • Is this the wrong place to ask a question?
Pixie40
Level 10
I'm not finding any information on this "360 grid" to begin with. To be fair though, I don't use the Netflix vr app either. That said, have you looked in the settings menu? If it's possible, it should (in theory) be there.
EDIT: If you mean the Quest's guardian grid, that is in the Quest's settings menu, I think. Although unless you have glancable boundaries on it shouldn't be showing up unless you get too close to the guardian. Or maybe (depending on your settings) if someone else or a pet enters your VR play space.
