Is it safe to charge Oculus Quest 2 with a US to UK adapter?
hazelNUTX
I'm traveling to the UK and would like to bring my Oculus Quest 2 but want to make sure using a US to UK electric adapter to charge it there won't damage it. Does anyone know for sure if it's Ok? The last time I was there I assumed it was Ok and ended up frying an electronic device the moment I plugged it in. Thanks!
4 REPLIES 4
DaftnDirect
Volunteer Moderator
Volunteer Moderator
Hi @hazelNUTX , have a look at the power supply that came with your Quest 2. The UK one (as with most power supplies these days) states an input voltage range of 100-240V and I assume that's the same for the US version, in which case, there's no problem using your US power supply in the UK with a travel adaptor.
Intel 5820K OC@4Ghz, Titan X (Maxwell), 32GB Corsair Vengeance DDR4, ASRock X99 Taichi, Samsung 500Gb 960 Evo M.2, Corsair H100i v2 Cooler, Inateck KTU3FR-4P USB 3 card, Windows 10 Pro v21H1 (19044.1387)
TomCgcmfc
Level 15
Ya, I remember doing the same thing years ago with a 110v hairdryer plugged into a 220v socket, lol!
Just look at the fine print on the socket-side of your Q2 adapter and you'll see it is 110/240v, 50/60Hz rated so you will be fine using this in the UK with a simple wall socket adapter.
Thank you! I really appreciate it.
Thanks so much! This is very helpful.
