02-05-2016 07:38 PM
07-26-2016 12:08 PM
07-26-2016 12:23 PM
07-29-2016 02:46 PM
cybereality said:
No, I don't believe there is an option to run Rift other than 90Hz. Sorry.
08-03-2016 09:09 PM
fredcallagan said:
Just for whoever is having the same problem. My videocard is an MSI R9 295X2 and I needed a mini displayport to HDMI adapter. Tried 8 different models and I can confirm that I found 1 single model that worked so far. Here is a list of models i tested and DID NOT WORK AT ALL:
Mini DP Adapter, [4-in-1 Adapter DP 1.2 Version/4Kx2K], Rankie Mini DisplayPort (ThunderboltTM Port ...
CSL - 4K Ultra HD Mini Displayport to HDMI Adapter with audio transmission | certified | for Apple /...Sold by: Your IT Delivered (Combined with a displayport to mini display port)
Also tried the CAC-1170 that is an actual mini display port to HDMI from Club3d and did not work as well.
StarTech Mini DisplayPort to HDMI Audio - Black
Mini Displayport To HDMI Adapter Cable For Apple Macbook, Macbook Pro, Imac, Macbook Air, Mac Mini L...
Mini DP to HDMI, Rankie® Gold Plated Mini DisplayPort (ThunderboltTM Port Compatible) MiniDP to HDMI...
So avoid all the adapters above non of them worked, some had strange pink/green lines on the image and the rest just did not turn on at all. The Club3d one was displaying and the image was going off every 1 or 2 seconds.
NOW GOING TO THE ONE THAT MATTERS AND DID WORK PERFECTLY:
Cable Matters® Gold Plated Mini DisplayPort (Thunderbolt™ Port Compatible) to HDMI Male to Female Ad...
This one is the only one I found here in the UK that does work perfectly at least with my R9 295X2.
Now I'm back to packing up 7 returns for the non working ones.
Good luck and enjoy the rift
08-05-2016 11:44 AM
Do I have any pros / cons if I use a DisplayPort Adapter for the CV1?
Or it's better to connect the 4K Screen to a DP and use HDMI fo CV1? If the CV1 is connected to my DP I got an HDCP error (Event Viewer). But maybe that's not a Problem...
08-08-2016 04:04 PM
08-12-2016 06:35 AM
I7 10700K, RTX 3070, 32GB DDR4 3200Mhz, Oculus Rift CV1
08-15-2016 11:56 AM
08-16-2016 04:09 PM
10-19-2016 08:21 AM
