Showing results forย
Search instead forย
Did you mean:ย
Making custom lens adapters. Includes 3D print and custom lens sources + installation tips and notes
HoIIywood
Level 7
--Update June 2019
Includes adapter for Go, Quest and Rift S
-- I am aware VR labs published an article on their page about confirming the earlier waves of the lenses were shipped out with ill fitting adapters, and this had been rectified. However when I asked them to clarify further and if this was still an issue in any way, I received no response. --
Therefore, I had been following the topics elsewhere about making your own adapter because the fit quality of the VR labs lenses were still poor according to recent buyers (and they also are expensive lenses).
I have since gone the DIY route and having received all the pieces back, they are fitted and working 100% in my Rift. There is less than 1mm of space between the two lenses(inserts and the original Rift), that can be adjusted minutely back out to about 1.5-2mm if you desire.
I suspect most people will get them as close as possible without touching, as they stay in place.
Adapters Go, Quest and Rift S
Popular round lens base design https://www.thingiverse.com/thing:3642004 to be used in conjunction with lenses http://www.zennioptical.com/buy/550021
This uses the same model Zenni lenses as previously, meaning should you own the lenses, you can insert them into the adapter instead of having to purchase new ones.
Adapters Rift
1. Popular round lens base design  http://www.thingiverse.com/thing:1602460 comes in 40mm or 43mm variant to be used in conjunction with (http://www.zennioptical.com/buy/450015  or http://www.zennioptical.com/buy/550021)
2. Revised version of above, http://www.thingiverse.com/thing:1644318 includes wider adapter frame, tighter fit and detachable lens inserts. Comes in 40mm or 43mm variant to be used in conjunction with (http://www.zennioptical.com/buy/450015  or http://www.zennioptical.com/buy/550021)
3. Alternative design for Zarruchi lenses, good option for Australian based users who want local dealings http://www.thingiverse.com/thing:1812540  (http://www.4eyesoptical.com.au/6-standard-frames-discount-glasses-from-59/47-zarruchi-z04-black.html)
4. VR lab official https://vr-lens-lab.com/media/Riftlensdetails.stl
Uses the Rift standard sized lens**
5. VR lab lens alternative. http://www.thingiverse.com/thing:1655410 like you would receive from VR labs, yet with a stronger fitting one piece frame. Uses the Rift standard sized lens**
** Sizes are HxW:
Rift - 51.8mm x 54.7mm
Vive - 50.1mm 46.7mm
Where to print/buy
https://www.3dhubs.com/3dprint
1. Upload your .stl file(s) {which you downloaded earlier from the links above in this post}
2. Select 'General Purpose Plastics'
3. In the filter section, select 'Recommended' and then leave the others at default.
4. To the right, input your location either by zip/post code, state/province and/or country
5. Below that is a 'materials' search box. Input "PLA" no quotes and then hit the Enter key
6. Browse your results
Things to look for :
  • Available material -  ideally they offer ABS, though PLA will do. Additionally clicking on 'See All Materials' (if given) will bring up another window, that indicates other materials available and on the right side column, the cost to change the micron or layering level. As a reminder, 200 microns is fine for this adapter, and 100 is even better).
  • The price (which is calculated for one quantity of the print .stl you uploaded
  • The delivery service they offer and it's related price
  • The ready by date is how soon it can be made, not delivered.
None of them speak about infill, though I suspect as long as it's structurally intact, then it does not matter - in fact the less infill the better to save weight on your face.
If you are a UK resident, I highly recommend using George's shop as pictured above. He was able to make them the same day and shipped the next business day. The print was expected, finished well and fit as intended.
A direct quote link for him : https://www.3dhubs.com/service/cncvac2   (click on Get a Quote From this Hub at the top right)
Please give George a try if you are UK based. Feel free to ask questions. He's an engineer and physicist...a 'boffin' as it were.
If you have any others to suggest, please do and we can compile a list based on location for everyone's ease of access and use.
Where to buy lenses
40mm - http://www.zennioptical.com/buy/450015
43mm - http://www.zennioptical.com/buy/550021
Rift standard - https://vr-lens-lab.com/
Notes on the Lenses
First and foremost, if you have not had an eye exam in less than a year, have one done. It may be premature, though better to be accurate now than order lenses that are for an aged prescription. And you can find out your correct IPD which is important whether you use corrected vision or not.
If ordering from Zenni, I would recommend that you meet your prescription in every way possible including Prism***
  • Anti reflective - oleophobic coating
  • No blueguard**
  • No high index* (unless your prescription requests it)
  • No other features
Note on IPD courtesy of tanvach :
For Go, Rift and Rift S users: use your measured IPD.
For Quest users: use IPD 65mm to align with the optical centers of the headset lenses. You can then use the physical IPD adjustment on the headset to change the IPD.
*** Prism is extremely important when using the Rift and other similar devices. I wrote a post (see last https://forums.oculus.com/community/discussion/comment/470534#Comment_470534) in another thread about this and the further considerations on why it is important due to light refracting and also why the VR lenses are optically a poor choice.
Also know that prisms are usually spread across both eyes. If you have a prism in your right eye of +3.0, your prescription most likely reads +1.5 prism on each eye, and then the the direction or 'base' which could be "up" or "out"
If you have a really low prism such as +0.50 then it's unlikely it is spread onto both eyes, as the lower number you get, the less possible it is to split the prism. Zenni do offer 0.25 though I wouldn't risk it. Stick with the recommendation by your optometrist.
Zenni will ask you to submit information for both eyes if you opt for a prism adjustment. If you only have it on one eye, then leave the other eye information blank.
** The jury is still out on the significance of blue light when using digital devices and whether it affects your meletonin. If it is not in your glasses prescription, then skip it.
* High index is about aesthetics in most cases, for those with high prescription that results in thick lenses, it allows them a more thinner pleasant looking lens. The extra thickness should be on the back side of the lens, not the front, meaning it won't cause spacing issues between the Rift lenses and the adapter lenses. This is another reason to avoid reversing the orientation of the lenses as discussed in the thread I linked above.
Installation (Go, Quest and Rift S)
  • Pay careful attention to the top area of the lens alignment while it is still in the glasses frame. It is advised to mark it with a Sharpie or similar style marker at the top's flat side. You will not see it in your view when playing
  • Before putting in the adapters, snap the lenses into place.
  • Once you are happy with the fit, install
Installation (Rift)
  • Do one lens at a time
  • When removing the lenses, check the underside of where the frame meets the lens to see if there's a small screw. If so, loosen it and the lens will come free ; otherwise they may be push out lenses. Zennis listed above are the screw type.
  • When you slot the lens into groove of the adapter or adapter frame, pinch it at the top and bottom firmly but not excessively. Then put it up to your respective eye and gently rotate it with the free hand - just to ensure that the 'top' point you marked earlier does indeed give you the best vision. You will know because to much deviation and you will start to lose focus or clarity. Once you are happy with the alignment, you are done. If you are using the version with removable inserts, do as recommended above for the alignment, yet then also hold it a bit tighter afterwards while you insert it into the frame itself. Once it's in, it will be harder to rotate than before though it can be done if you need final adjustments.
Final thoughts
  • Eliminated the pain and inconvenience of glasses
  • Eliminated the pain and inconvenience of contacts
  • Means Lasek doesn't have to be in your future
  • Cost effective vs other marketed solutions
  • Suitable for any one whom already has prescription or plano glasses
  • Confirmed working, stable
  • Provides better FOV
  • Protect your HMD's lenses
  • Makes sharing the HMD with others easier and better, particularly with the hot swap adapter versions
If you've been toying with this idea, take the plunge, it is worth it. The turn around time for all the parts was less than two weeks.
If there is another thread already going on this subject, please send me the link.
8 REPLIES 8
HoIIywood
Level 7
Reserved for followup notes.
HoIIywood
Level 7
Original thread overhauled as new adapter tested and working.
All new information included for others to follow.
elboffor
Level 12
Forgive my ignorance here, but does one of those links go to a cad file for the fac-ial interface?
I wouldn't mind making my own version of the vr-cover is all
This is my forum signature.
HoIIywood
Level 7
That is correct, the links to thingiverse are for the .stl files for the adapter(and any lens inserts) that you would have 3d printed.
The other links are for the respective tested and confirmed working lenses you can purchase.
elboffor
Level 12
Nice
voxelmaniam
I realize that this discussion refers to the Rift. How similar are the Go adapters to those used by the Rift?21kj7gnpt9xz.jpg
A voxel is a three dimensional pixel!
Murray Foster
HoIIywood
Level 7
@voxelmaniam
I would not be able to answer that, though this version may be for you :
The new VR headsets have spacers and forward adjustment however any time you make such amendments, you sacrifice FOV.
From what I have tested, the Go, Quest and S models do not have the same internal face plate and as such anything you 3D Printed or purchased for the Rift before the other products launched, will not fit.
The above should be the way forward and will take the same lenses from Zenni
HoIIywood
Level 7
Please know I am no longer able to give advisement on this topic for the Rift.
However the general aim should still be valid and the data for the original Rift is accurate.
