2 weeks ago
My C: does not have enough space for the oculus app to update so I tried using the supplied command on the oculus website to move it to a new directory but it only reinstalls it back on the C: - can anyone help with this? Thanks.
2 weeks ago - last edited 2 weeks ago
Use a symbolic linked folder on another drive for your games.
Google it.
2 weeks ago
It's not an issue with the game directory as it allows you to install them to another drive. My issue is with the actual Oculus Application itself. I need to move it from my C: because I don't have enough space for it to update.
2 weeks ago
If you move the games directory (which takes up the most space) to another drive, you should have enough space left to do the update.
2 weeks ago
I wish I did but sadly my C is tapped as it's a very small SSD OS drive. That's why I need to move the install directory but the command Oculus has listed to do so on the support page reinstalls it back on C for me sadly.
2 weeks ago
And that's where the symbolic link comes into play.
Oculus thinks it's on the C: drive but the link allows you to put it somewhere else.
2 weeks ago
oh so simlink the entire oculus directory ? I will try that! Thanks
