Multiple sensor placement profiles
Drizzt321
Honored Guest
I'm fairly new to Rift, but the games I play are mostly through SteamVR, and some a keyboard + mouse work fine, which would be much, much closer and with different sensor angles than other games where I use the Touch controllers. Is there anything that supports having multiple sensor/orientation settings setup and switch between them?
Madmatt2525
Honored Guest
There was a small profile switching profile that was being worked on in this thread that showed a lot of promise (https://forums.oculus.com/community/discussion/50439/ohmutlitool-beta-release-v0-2/p1) but unfortunately the guy working on it hasnt had time to update it. Shame because it looked like his next version was going to not only allow multiple profiles but also have profiles include different amounts of sensors.
Maybe some day he will find time to resume...
Madmatt
Drizzt321
Honored Guest
Thanks, hopefully his life will open up and and can get it going. At a guess Oculus doesn't really want to support multiple profiles...which is stupid. *sigh*   Well, it's relatively early days for VR HMD.
