My Photograph With My Username
CaryMGVR
See how your Oculus username pane has your picture in it?
https://imgur.com/a/U60oaKB
[And I only used @cybereality as an example because he freely offers it]
Well, here's mine ....
https://imgur.com/a/rruH0Ng
See how my picture's not in the circle?
How do I put my picture in the circle?
Thank you!
15 REPLIES 15
nalex66
Volunteer Moderator
Volunteer Moderator
I have mine from setting it up in the PC Rift app (same Oculus account). I don’t see a way to do it in the Go app.
i7 5820K @ 4.25GHz | RTX 3080 Ti FTW3 | Gigabyte GA-X99-UD4 | Corsair DDR4 3000 32GB | Corsair HX 750W
CaryMGVR
OK, that's fine.  But how do I do it *wherever*?  Thank you.
nalex66
Volunteer Moderator
Volunteer Moderator
If you install the Oculus Rift PC app from here, you can sign into your Oculus account and edit your profile. You’ll just have to skip past all the Rift setup stuff.
CaryMGVR
Ohhh ....  It's an .exe  Anything for Macintosh?  Thanks!
cybereality
Level 15
Currently, the only way I know to change your avatar picture is inside the Oculus PC application. I thought the Go mobile app allowed you to select it on initial account creation, but I already had an account so I never tried this. It is something I agree we should have, and I can share your feedback with the team.
CaryMGVR
Yes, please share my feedback with the team.
When I made my Oculus account on the website, there was no provision
whatsoever to include my picture.
When I first signed-in on the iOS Oculus app, there was also no provision
whatsoever to inlude my picture.
Next to my avatar picture is a red circle with a silhouette in it ....
https://imgur.com/a/1I9orzr
Looking at it, you'd think: "OK, that's where MY picture goes."
Plus, lookiing at other people's avatar panes, *their* pictures are there.
But when I was signing into the Oculus iOS app, and every time since,
whenever I try tapping on the red circle
(expecting to see the iOS photo choosing pane:
https://imgur.com/a/iAaWIB3 ), nothing comes up.  So there we are.
Thank you.
CaryMGVR
When creating my Oculus account on the website, there was no provision whatsoever
to add my picture.  Same thing when logging into the iOS Oculus app for the first time.
In the app, my avatar pane shows a red circle with a silhoutte in it:
https://imgur.com/a/HJRbDpX
So I think: "OK, that's where MY picture goes."
Plus, in everyone else's avatar pane I've seen, that's where they put THEIR pictures.
But both when logging into the iOS Oculus app, and everytime since then,
whenever I tap that red circle expecting to see this: https://imgur.com/a/eGokNwJ ,
instead, nothing happens.  So there we are.  Thank you.
danknugz
Level 9
mac user scum stop making shit threads, take the 5 minutes to read instead of needing your hand held for everything.
A: Because it messes up the order in which people normally read text. Q: Why is top-posting such a bad thing? A: Top-posting. Q: What is the most annoying thing on forums?
nalex66
Volunteer Moderator
Volunteer Moderator
@cybereality? This time-out jail cell doesn’t seem to be doing it’s job.
