I'm just going to throw my feelings on paper as they occur to me, a random train of thought if you will.
BOX Well packaged with a premium feel.
SETUP Ridiculously easy to setup, far easier than expected.
FIRST PLAY The resolution feels the same (its close) to my Galaxy S6 on my Gear VR. SDE is similar to that device (Samsung use amazing screens)
Dream deck demo was ok. I enjoyed the Batman-esque building demo, looking down at the cars. And the TRex demo was great too.
Watched Henry, very enjoyable by this time I'm noticing the limitations of the lenses, and the God Ray effects. Not bothered by them though . . . It's the experience that matters most.
Next just Assetto Corsa. Looks terrible, so I do some research and find out that I need to turn off the in game AA and Post Processing, and go into the Oculus.initial file and change pixel count to 1.5.
After these changes it's fantastic . . . . The reason I purchased a rift can be summed up by what I spent my time doing:-
A Lotus 49, no driver aids, around the Nordchleiffe. . . . THIS is VR. Sold
NEGATIVES Nothing in life is perfect and it's the same with the Gen 1 consumer rift.
My lenses look cloudy, like there are bits of dirt on the screen all over in certain lights, i thought i hadnt removed the plastic covers, but I had.They also look slightly reddish in dark scenes. I'm not too bothered though, unless I find out this isn't normal.
All in all a good experience. I had my expectations in check, and it's a good product.
Final thought, every game ran perfectly on my GTX970 apart from Pcars, which I had to run on low. Was still fun though. I have a 1080 on the way anyway.
Exactly my thoughts but I didn't know that about AC? Could you run through what changes you made mate? And you are right, if you look past the limitations it's a great bit of tech.
Essentially turn off AA Turn off all Post Processing Turn off Vsync Unlimited frames In the Oculus.ini file, set the audio to 1 (so it comes through your Oculus headphones) and the pixel density to 1.5, or higher with a better card.
I did some racing in AC last night with those settings. AA & PP off and pixel density of 2.0 in the oculus.ini file in the cfg directory. There is some shimmering due to AA off but otherwise the image is very clear & sharp/bright.
Yup tried it and the clarity is way better and it's not washed out or anything. I did get a little nauseous leaning into the corners as the car turned in but much much better 😉 and I'll buy dinner on our second date lol
