No fix for Displayport disconnection issues ???
Drakeos99
I been having this issues since stupid 27 came out and constently disconnecting me (wires are fine and my CPU/graphic card is fine) it's the software that needs to be fixed ASAP or you be losing customers
Okay let me put you out of your Oculus misery. Your cable and headset is fine.
The problem you're seeing is caused by the headset demanding more power than the USB bus of your system can give. I had this issue and ended up getting three replacement headsets sent.  Save yourself the inconvenience and get a mains powered USB 3.0 hub. I picked one up on ebay and has fixed my DP-port/USB port disconnection nonsense.
