Oculus 2 Link Cable not connecting to the Oculus app
QPilot
I have a very annoying problems.  I was able to connect the cable from my quest 2 to the pc and I would hear the connection sound from my pc as well. That I know it is connected.  In the vr, the messages, "allow to access to data" and I click deny as directed from oculus in order to use the app in the pc. So when I did it, the vr would go black for about a sec and send me back to the home screen and a disconnect and reconnect sound play from my pc play. And then the vr give me a notification saying, "Link app has stop working". I have even go out and buy 2 more quest to see if this was a defective or not. I even spend the whole day with the oculus chat support trying ALL the possible troubleshooting solutions and sending my PC log. And guess what? They don't know why this happen. I can not believe how much I spend for something small like this can be fix. So many other people having the same problem. I know it isn't my computer because it is pretty good for vr and gaming.
My pc spec;
Cyberpowerpc Gamer Supreme
- AMD Ryzen 7 3700X
- 64GB of RAM Memory
- AMD Radeon RX 5700 XT
- 7TB SSD
4× USB port
1× 3.0 USB port
1× 3.2 USB-C port
I am very annoy as I do not want to return it because I already bought a few game from them. But when people ask me if I would recommend this to them. I will just tell them my problem I had with it and won't be happy to recommend it to anyone.
__________________________________________________
Please note:
-All software on the pc and Quest 2 are up to date.
-What I test the cable, it can't even start the test but able to detect the connection.
-The air link option was off.
-I am using a AMD Radeon gaming software(I haven't look much in this yet, not good enough to do it by myself)
-Done all the factory reset on the Quest.
-Disable the auto pc put USB to sleep in device manager.
Any tip or advice is appreciated.
Q.D
3 REPLIES 3
TomCgcmfc
Level 16
Sorry to hear of all your problems mate, very sad.  All I can suggest is to get rid of your amd gaming software (= bloatware).  Also, maybe try a different gpu driver.  Seems many have had better luck rolling the driver to an earlier one.  I cannot say this would help since my nvidia gpu does not have any problems with Link, using the official link cable connected to my MB usb3.1 gen2 type-c port.  You may also want to try one of your usb3 ports with an adapter like this one;
https://www.amazon.com.au/gp/product/B074V4QBS4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Anyway, good luck and I hope you finally get this going ok mate.  Cheers.
Hey man, thank you for the reply and tip. I have even try a usbc to usb 3.0 adaptor as well and it still didn't work. But then I realized that I forgot to try to, "run as administrator" and when I did. It work. Lol. Idk why oculus support tech didn't know to try this at first. But I will check again today to see if this is only a lucky thing or actually work. I'll let u know
Q.D
Hello again, so I just try it again and it still didn't work. It probably just a luck thing.
Q.D
