Oculus Injector X-Plane Fix Edition
System1
This discussion was created from comments split from: VR won't load. X Plane 11 - Rift S.
20 REPLIES 20
cpignol
Thanks for the great work. Install the Injector and define an Entry. I use an X-plane 11.41 validated with a CD. and steamVR version 1.11.13) for occulus rift. Xplane 11.41 the VR doesn't work as already mention multiple time.
With the injector I was able to start twice X-plane 11 after a lot of attempt. When X-plane starts with the injector the VR works.May be a security problem? Any idea? Thanks
Did more test and can not find why the process X-plane failed to start 99% of the time and need a lot of attempt  to finally successfully start. It seems to be random. Very strange.
Anonymous
Not applicable
Thanks for your help (both) I found the .exe and I run the injector but x-plane is still saying that headset is disabled and automatically unchecks the box for enable VR hardware. I don't know how to make the Xplane runs with Oculus Rift S. I will very appreciate if you can help me.
Im having the same problem here. I think i read somewhere that steam version has differences from the laminar download. i dont know if that's the reason
cpignol
Never had any problem with steamVR it was running fine until we get this problem that X-pane  VR won't load with version 17.
melvilg
I managed to install the kojak Oculus Injector program and now Xplane VR is working fine. Both the Rift headset and Quest link headset are working so this is a great fix. Great work kojak! Why doesn't Xplane buy your app??
kojack
Volunteer Moderator
Volunteer Moderator
I'm pretty sure I know why people with the Steam version can't run the fix: X-Plane uses Steam DRM.
This encrypts the X-Plane executable. When OculusInjector loads the executable, it's really loading Steam's copy protection code and hooking that. Steam decrypts the game into memory and runs that. Without trying to bypass Steam's protection, there's no way I can get access to where the oculus library is really loaded. At least not with the technique I'm using. I've got an idea, but that will have to come later.
The same thing happens with Euro Truck Sim 2, I can't hook into it because it uses Steam DRM.
The Oculus store's entitlement check is much less intrusive and doesn't get in the way of my code.
kojack
Volunteer Moderator
Volunteer Moderator
Hmm, I've never split comments out of a thread before. I didn't know it leaves an ugly system post at the top. 😞
fly4fun
Thanks for the solution, it is really neat, compared to other proposed options. However, for some reason Orbx products and sceneries do not load up when using injector, everything else, like 3rd party airports from other developers load normally. Anybody else came accross the same issue? For reference, I have XP11.41 and I was flying over TrueEarth Washington state (default landclass and not photoreal as it supposed to be) and landing at Israel's farm (WA56 - default look). When I run 11.41 without the injector, the sceneries appear as they are supposed to. It seems that Orbx uses or adds something to either command line that direct link with the injector to xplane.exe misses.
kojack
Volunteer Moderator
Volunteer Moderator
Not sure about Orbx, I haven't used any of their stuff.
Laminar have released a fixed executable of X-Plane 11.41 stable. It seems to work now.
No official solution for 11.50b9 beta though, but at least it has Vulkan mode which bypasses the issue.
Later I'll re-enable the in depth logging in my tool and see what the fixed version is doing differently.
TomCgcmfc
Level 15
Good to see Laminar and Oculus working together to at least provide a hotfix for 11.41 OpenGL.  Only applicable for Oculus headsets with xp11 download and/or CD versions.  Does not apparently work with Steam versions yet.  Hopefully the next xp11 and Oculus updates will sort this out for all.  It would be nice if they can fix the xp11 shutdown bug that reappeared with Oculus v13 as well.
Thanks again for all your efforts kojack.
kojack
Volunteer Moderator
Volunteer Moderator
No prob.
I guess this is a good reason for not buying from Steam when a company has their own store. Laminar has full control over releases on their own version and 100% of the money goes to the actual game company (instead of the 30% cut most stores like Oculus and Steam take).
Even if it's cheaper on Steam, I like to support the developers when I can.
