Oculus Need To Update Recommended Specs
scottycam
Currently Oculus say that the recommended specs for the Operating System is Windows 7 SP1 or newer.
With every rift being shipped with an Xbox one controller and likely every game going to use it they need to update the recommended Operating System. The Xbox one controller will only be usable with Windows 10, so this is actually the minimum OS required.
22 REPLIES 22
Arnklit
The XBox one controller is supported on Windows 7. You can use one on it right now if you want, but the wireless dongle is for some strange only supported on Windows 10.
So annoying as a cord might be, recommended spec is indeed Windows 7.
scottycam
Yea so if the Rift ships with a wireless xbox one controller wont that only work on windows 10?
Tim74UK
I have a wireless xbox 360 controller... Windows 7 ultimate 64bit... works a charm.
My Rig: - Gigabyte Z97 X5 MB / Core i7 4790K @ 4.4Ghz - Water Cooled Coolmaster AIO Loop (Push - Pull Config)/ 16GB Corsair Dominator ram at 2400Mhz / Palit Jetsteam GTX 980 OC edition / 250GB SSD OS / Program Drive + 2 TB hard drive storage / Win 10
scottycam
Yea I currently use a wireless xbox 360 controller on windows 7 too.
If I understand correctly though you can not use a wireless xbox one controller on anything but windows 10 and the Rift will ship with a wireless Xbox one controller.
So every Rift owner will have a wireless Xbox one controller that will only work on windows 10.
benplace
Level 8
Where are you getting this info?
It says on Microsofts official site that the controller supports 7 and 8.
http://download.microsoft.com/download/3/3/8/3380DCA0-E4CE-4E8E-AFF7-2C36EE48DCB2/TDS_XboxOneControl...
Tim74UK
I think where the confusion comes from that you can use an xbox one controller with windows 7 but as far as I am aware only wired.
Whereas the xbox 360 controller can be used wireless using a microsoft xbox bluetooth dongle.
scottycam
http://www.polygon.com/2015/6/9/8752747/xbox-one-wireless-controller-adapter-will-only-work-with-win...
The Xbox Wireless Adapter for Windows, which will allow an Xbox One controller to work on a Windows computer, will only support Windows 10, Microsoft confirmed to Polygon today.
http://venturebeat.com/2015/06/09/xbox-one-wireless-controller-adapter-for-windows-10-only-goes-on-s...
Releasing this device is an important step for Microsoft. It previously provided a similar dongle for wireless gameplay with the Xbox 360 controller during the last generation, which was part of that joypad turning into the standard input device for both Xbox 360 and PC releases. The difference this time is that the Xbox One controller will only work with Windows 10.
http://www.windowscentral.com/xbox-one- ... apter-fall
This ones part of a direct quote from Microsoft.
With the Xbox Wireless Adapter for Windows, you'll simply plug the Adapter into the USB 2.0 or 3.0 port of your Windows 10 PC
http://www.vg247.com/2015/06/10/xbox-one-wireless-controller-adapter-only-works-with-windows-10/
Xbox One wireless controller adapter only works with Windows 10
There are more but that should be enough for proof. Most of those were published with in the last 7 days too.
Crespo80
on that sheet, it says
Proprietary, dual band 5 GHz wireless (Wireless use on Xbox One platform only)
scottycam
Yea I believe you can use a wired Xbox one controller but the issue I see is that every Rift owner will have a wireless xbox one controller and they are also being told they only need windows 7. The controller will not work unless they upgrade to windows 10.
