05-15-2015 01:39 PM
05-15-2015 01:50 PM
05-15-2015 02:04 PM
"cybereality" wrote:
...For Windows 7 in Extended Mode, any monitors connected to the computer go black when the headset is on and return to normal operation when the headset is removed. For Windows 7 in Extended Mode, if the headset is placed above the monitor(s), all displays might go black. The workaround is to place the headset to the right or left of the monitor(s).
I7 10700K, RTX 3070, 32GB DDR4 3200Mhz, Oculus Rift CV1
05-15-2015 02:20 PM
05-15-2015 03:31 PM
The G-Sync issue was not fixed, so this is not surprising.
In terms of Extended Mode, it now displays a black screen on the DK2 until you run a Rift compatible game. The monitor will then turn black while the VR game is running.
05-15-2015 03:40 PM
05-15-2015 03:43 PM
05-15-2015 06:00 PM
Make sure you are on the latest version of Elite.
Also, can you describe your problem (assuming you are on the latest version)?
05-15-2015 07:12 PM
"cybereality" wrote:For Windows 7 in Extended Mode, any monitors connected to the computer go black when the headset is on and return to normal operation when the headset is removed.
05-15-2015 09:12 PM
