Oculus Quest 2 64GB VR Headset - Apple type-c data cable question
Csatika01
My Macbook Pro Original Type-c Cable compatible the Oculus Quest 2? All i need is a data cable. Thanks
PITTCANNA
Level 12
what are you trying to do?
All you need is a charging cable to charge the battery.
If your looking for sidequest loading a data cable will work you don't usb 3.0.
If your going to do link you can't do it with a mac.  But you need a usb 3.0 cable to do link anyway.
Csatika01
Hy,
i want to use data transfer(100-200MB data) the apple type-c cable , I would have a question compatibe the original apple cable to Oculus Quest 2 and MacOS Big Sur operating system?
Thanks!
