Oculus Tray Tool current version: 0.87.0
What is it? In short; It’s a free application that helps you get the most out of your Rift. It is developed by me, ApollyonVR, with the support of the community for beta testing. Please note that this application is not an official piece software from Oculus, I am not affiliated with Oculus in any way. Any issues you
have with this application should be reported to me and not Oculus support. You can reach me here on the forums or by contacting me at ApollyonVR@gmail.com
Oculus Tray Tool (OTT) has many features that will hopefully help you get the very best VR experience. It has options that help you automatically switch audio and microphone to the Rift and back, handle the Oculus runtime service, voice commands, batch import Steam games (added to OTT by the awesome @headkaze over at
http://headsoft.com.au), replace icons for your games and more.
It’s primary feature however, is the ability to create “Profiles” for you VR Games and apps.
Within these Profiles, you set how Asyncronous SpaceWarp (ASW) should act, increase the perceived resolution by using Supersampling and increase the CPU Priority of a given app to get the most juice out of your system for that specific application.
Once a Profile has been created for a game or app, OTT will detect when it is started and apply the
profile for it, without the need for taking your headset of.
If you want to have a peek at all the things OTT can do for you before installing the application, check the
User Guide pdf. The latest version of this application will always be right below this intro, but the app also checks for available updates on startup.
Enjoy, have fun and please report any issues, suggestion or feature requests to me using the above mentioned methods. Oh, and feel free to buy me a coffee by using the PayPal button in-app.
The very nice people over at Guru3d.com have been kind enough to host some mirrors for the setups, so make sure to pay them a visit!
UPDATE 01/18
Version
0.87 is out with a minor change. You can now set the CPU priority of OVR Server to whatever you want, instead of just 'Above normal'.
Hopefully this can help out if your games suffer from stuttering.
.exe:
https://bit.ly/2LMY0No.zip:
https://bit.ly/2NiJ22fChangelog version 0.87.0
* Removed option "Set OVR Server Priority to 'Above Normal'.
* Added new dropdown option for OVR Server priority on the Game Settings tab.
Values are: Normal, Above Normal, High, Realtime
UPDATE 01/06Version
0.86.9 is now available, mostly buggfixes in this one.
exe:
https://bit.ly/2KGz1uOzip:
http://bit.ly/3olrHTMNote that for Microsoft Store apps, like MSFS2020, you need to gain access to the Windows Apps folder. After this, you can add a profile
for MSFS2020 where you manually browse this folder to find the installaion directory for MSFS2020, and in there you will find "FlightSimulator.exe"
and can add that to the profile. The below guide will show you how to gain access to the Windows Apps folder.
UPDATE 11/12
Version 0.86.8 is now available for testing if anyone wants to try it out. Let me know of any issues you might have.
I was previously not able to login to the forums without a facebook account, but now it seems the regular email option is back
(or it never went away and i've just been too damn tired..) Anyway, this update has been lying around on my desktop for a while now
so feel free to try it out.
Changelog version 0.86.8
- Removed several features that was 'fun to add' but did not really add much usability to the tool, but did increase complexity.
- Added 'Bitrate' option for Quest Link. This option is currenly only available in Oculus App version 23.
- Steam VR games and apps are now added automatically to the Profiles game list without needing to first have them imported to the Oculus library.
Note that the Library view, with the nice game icons, still require you to have the game/app in your Oculus library before it is visible there.
