Oculus TrayTool - SuperSampling profiles, HMD disconnect fixes (hopefully)
ApollyonVR
Level 8
Oculus Tray Tool
current version: 0.87.3
What is it?
In short; It’s a free application that helps you get the most out of your Rift. It is developed by me, ApollyonVR, with the support of the community for beta testing. Please note that this application is not an official piece software from Oculus, I am not affiliated with Oculus in any way. Any issues you
have with this application should be reported to me and not Oculus support. You can reach me here on the forums or by contacting me at ApollyonVR@gmail.com
Oculus Tray Tool (OTT) has many features that will hopefully help you get the very best VR experience. It has options that help you automatically switch audio and microphone to the Rift and back, handle the Oculus runtime service, voice commands, batch import Steam games (added to OTT by the awesome @headkaze over at http://headsoft.com.au), replace icons for your games and more.
It’s primary feature however, is the ability to create “Profiles” for you VR Games and apps.
Within these Profiles, you set how Asyncronous SpaceWarp (ASW) should act, increase the perceived resolution by using Supersampling and increase the CPU Priority of a given app to get the most juice out of your system for that specific application.
Once a Profile has been created for a game or app, OTT will detect when it is started and apply the
profile for it, without the need for taking your headset of.
If you want to have a peek at all the things OTT can do for you before installing the application, check the User Guide pdf. The latest version of this application will always be right below this intro, but the app also checks for available updates on startup.
Enjoy, have fun and please report any issues, suggestion or feature requests to me using the above mentioned methods. Oh, and feel free to buy me a coffee by using the PayPal button in-app. 🙂
The very nice people over at Guru3d.com have been kind enough to host some mirrors for the setups, so make sure to pay them a visit!
UPDATE 04/20
Thanks to my awesome girlfriend, OTT now has a new home! Check out the new website over at https://apollyonvr.wixsite.com/vrtools for current and future downloads. Feel free to continue
using this forum for discussions and bug reports.
Cheers!
1,848 REPLIES 1,848
@tolgayilmaz86  I just tried to download the latest version from the OTT website no problem.  Maybe check your virus checker and/or firewall is not the problem.
https://apollyonvr.wixsite.com/vrtools/oculus-tray-tool
Also, some servers can be down for maintenance occasionally so maybe try again later.
Hi just checked the source links I got SSL_ERROR_RX_RECORD_TOO_LONG error on firefox (on edge as well)
Since I'm having no issues on other versions decided to investigate further and compared the workink link(0.87.3) and encountered a difference like below.
When I changed the usrfiles.com -> filesusr.com I was able to download 0.87.4.
https://88ca3779-cc1e-4e79-9548-767ff889ec02.usrfiles.com/archives/88ca37_f6907270a88d4eefac385aec7ed53d92.zip?dn=OTTSetup_0.87.4.zip
https://eddd3285-7ae2-4ef4-930c-a438adf10e58.filesusr.com/archives/88ca37_83c3c119f969437ca9b70da131b3b6d8.zip?dn=OTTSetup_0.87.3.zip
Just reporting in case.
I had no problems using Chrome.
almarm74
Hi @ApollyonVR
Any way to render in one screen on Rift CV1 (monocular rendering)?
I Know can sound strange ask for this, but some people blind of an eye are looking for a solution to improve performance.
Thanks in advice.
tolgayilmaz86
Any idea why TT does not save OVR server Priortiy? I set it to High and save each time I've started it despite; it shows up with an empty field of priority each time again?
markhollis
oculus homeless not working with airlink
@markhollis You do not really need the homeless option anymore.  Just go to your Oculus desktop app settings general tab and at the bottom, disable start in Oculus Home.  Next time you will then startup in a homeless void.  You can still access your home using the dashboard menu.
@tolgayilmaz86 Maybe drill down your oculus runtime to see what the ovr64 services are set to.  Maybe it just remembers this.  Personally I have never seen any advantages to increasing this above Normal (default).  I have noticed that sometimes this OTT menu is blank but when I drill down to check it the priority is normal.  With current win10 updates you really do not need to much around with these anymore imho.  BTW, I also use OTT to turn on my Oculus runtime services when I start up OTT and stop them when I exit OTT.
keem85
Is it a possibility that you can make a function to have AirLink always active? It's so annoying having to go in to options all the time.
ThePixelCowboy
As a feature request, could we get profiles for air link vs wired link, so that the encoding bit rate is automatically adjusted?
