Oculus TrayTool - SuperSampling profiles, HMD disconnect fixes (hopefully)
ApollyonVR
Level 8
Oculus Tray Tool
current version: 0.87.3
What is it?
In short; It’s a free application that helps you get the most out of your Rift. It is developed by me, ApollyonVR, with the support of the community for beta testing. Please note that this application is not an official piece software from Oculus, I am not affiliated with Oculus in any way. Any issues you
have with this application should be reported to me and not Oculus support. You can reach me here on the forums or by contacting me at ApollyonVR@gmail.com
Oculus Tray Tool (OTT) has many features that will hopefully help you get the very best VR experience. It has options that help you automatically switch audio and microphone to the Rift and back, handle the Oculus runtime service, voice commands, batch import Steam games (added to OTT by the awesome @headkaze over at http://headsoft.com.au), replace icons for your games and more.
It’s primary feature however, is the ability to create “Profiles” for you VR Games and apps.
Within these Profiles, you set how Asyncronous SpaceWarp (ASW) should act, increase the perceived resolution by using Supersampling and increase the CPU Priority of a given app to get the most juice out of your system for that specific application.
Once a Profile has been created for a game or app, OTT will detect when it is started and apply the
profile for it, without the need for taking your headset of.
If you want to have a peek at all the things OTT can do for you before installing the application, check the User Guide pdf. The latest version of this application will always be right below this intro, but the app also checks for available updates on startup.
Enjoy, have fun and please report any issues, suggestion or feature requests to me using the above mentioned methods. Oh, and feel free to buy me a coffee by using the PayPal button in-app. 🙂
The very nice people over at Guru3d.com have been kind enough to host some mirrors for the setups, so make sure to pay them a visit!
UPDATE 04/20
Thanks to my awesome girlfriend, OTT now has a new home! Check out the new website over at https://apollyonvr.wixsite.com/vrtools for current and future downloads. Feel free to continue
using this forum for discussions and bug reports.
Cheers!
1,848 REPLIES 1,848
Nayanak
interested in testing this out myself aswell
SuperTuck
Works good.
danneman
This tool is awesome. I love it! So convient to have supersampling profiles, and a easy way to restart the Oculus Service to get rid of the infamous 4-sensor-laggy-hands glitch. You should share it on reddit.com/r/oculus 🙂
vermadas
I would like to try this out also. Great work!
ragesaq
I would love to have the oculus traytool!
Everlasting1
Add me to the test list! 🙂
iTsLiKeAnEgG
Please send me a link as well! Application based profiles sounds great.
OziOziOiOi
So many inconveniences solved! Sign me up too, please.
MarcBushido
Hi I would love to try this out.  Would really appreciate a link!  Thanks
dougchism
I would also like to try this out.
