Oculus and xbox one
jwydner
Can some one tell me which oculus system works with xbox one x
6 REPLIES 6
PITTCANNA
Level 12
none as far as i know.
Pixie40
Level 10
To my knowledge, none of them. None of Microsoft's consoles support VR in any way.
*researches via googling "what VR headset supports Xbox One X"*
Huh, learn something new every day. As it turns out, apparently you can use a VR headset with the Xbox One. It's not supported, and there are no VR games on the console. So you'd just be using it to play 'pancake' games on a virtual screen. But it looks like it is possible.
For which Oculus headset works, you apparently need to use the DK1, DK2, or the original Oculus Rift.
jwydner
Thank you
Pixie40
Level 10
Keep in mind, there's probably things you have to do to get the headsets to work with your Xbox One that those two linked articles don't mention.
T3chn0_Games
How do I connect to Xbox, Ive got a dk1
Pixie40
Level 10
The articles I linked don't say. But I'd imagine the process requires hacking your console, which will void it's warranty. Assuming it still has one. It might also get you perma-banned from Xbox Live if you try doing anything online.
