The troubleshooting with my Rift S exceeds the time I actually get to use it. With every instance of starting a new session, I will run into one or more bugs.
- a black screen, requiring me to re-seat the USB cable,
- 20 minutes into game play, one or more connections flake out for a second,
- restarting the software because it doesn't pick up the VR headset
- applying device breaking updates
- The displayport cable not being recognized despite the device being plugged in
- One or more controllers not tracked by the device.
- Controllers randomly disconnecting and not reconnecting until a rebind is initiated.
- right controller low battery warnings that aren't true
- applications opening in VR mode only to revert back to regular mode on launch head, tracking being passed to app but no video output to oculus.
- Guardian setup loop bug were setting up guardian it will persistently ask to setup a boundry and floor height, then returning to the beginning of the setup after successfully configured.
- intermittent USB disconnect issues
- head tracking faults and fails to recover.
- None of the operations of the device are fault tolerant. If any piece of the system stalls or has a brief issue, it will require a restart of the program you're using to get it to work again.
- and more
From what I understand these issues and more are not limited to the Rift S and Quest 2 has their own issues with PC link
