Ripping a 3D Blu Ray for Rift playback
VizionVR
Level 8
I'm at the end of my rope and need help from the VR community.
Has anyone figured out how to rip a 3D Blu Ray for the Rift? The only 3D rip that worked was an MKV I found on a pirate site, so I know it can be done. It played perfectly using LiveViewRift.
I have a legit licensed version of MakeMKV, but when I rip a disc it's not in 3D. What am I doing wrong?
I also tried to play direct from the Blu Ray, but PowerDVD (also legit purchase) says that the Rift isn't a supported playback device.
Help! :!:
Not a Rift fanboi. Not a Vive fanboi. I'm a VR fanboi. Get it straight.
25 REPLIES 25
cybereality
Level 15
I've used DVDFab Blu-ray Ripper (3D Plus) before, and it works well. Full version costs money, but you can test the trial just to see if it works (it will have a watermark but otherwise is functional). This was years ago when I wanted to play movies on my Zalman monitor. I haven't tried recently, but I imagine it still works. Just looking at options, Acrok Video Converter Ultimate looks pretty good as well. Though I've never tried it so who knows? Both are around $60.
VizionVR
Level 8
Thanks, I'll give DVDFab a try. Is LiveViewRift still a good app for watching 3D rips? There was a lot of fiddling around with it. Is there anything that requires less fiddle? 🙂
VizionVR
Level 8
Update-
Tested DVDfab. It doesn't work with protected content. Yes, I know I can use another bit of software to get past this but that adds considerable time to the process.
I think I found the easiest 3D BD ripper on the market. Pavtube BDMagic can convert directly from disc to side-by-side, top-bottom, or anaglyph stereo. I'm still experimenting with the output settings for best Rift 3D.
To be continued...
raidx
AnyDVD to bypass the protection
VizionVR
Level 8
True, but BDMagic bypasses protection AND rips 3D content, no need for multiple programs. So far it's working well. I've tested MKV, AVI, and MOV 3D output. Playing in LiveViewRift. I think I'll try MaxVR as a player, but I don't think it supports .MOV files.
cybereality
Level 15
Yeah BDMagic was the one I was thinking of but I couldn't remember the name. Glad you figured it out.
jordandavid513
I've had bee the pleasure of using EaseFab Blu-ray Ripper these past monts. It owns the ability to rip the 3D Blu-ray to sbs 3d mp4 videos for viewing on my Oculus Rift Dk2. Anyone who are intereted in that should give a try.
Lhun
imho do sbs if the video is cinemawide and top-bottom if it's 16x9, the result has more pixels.
if you're a developer you might want to consider this:
http://corecodec.com/products/coremvc
allows for full resolution 3d support without stereoscopic tricks but I don't think any VR media players have it integrated yet.
Gloriaivy
Oculus Rift DK2 does not included a drive for playing 3D Blu-ray movies. I have tried BDMagic and find it can successfully copy the most popular 3D Blu-ray for Rift DK2. So excited! So perfect application!
