Sensor Mount for Monitors? 3d printed?
dunginhawk
Good morning... I am trying to see if anyone has created a 3d print mount for sensors that would sit on top of a monitor?... I have a 43" super ultra wide, and I could put a sensor on each side and it be perfect... Just curious if there is one made.
If not, ill try to model one.
thanks
Nunyabinez
Level 8
thanks
https://www.thingiverse.com/thing:3048234
https://www.thingiverse.com/thing:3906371
https://www.thingiverse.com/thing:2197678
https://www.thingiverse.com/thing:3328920
Here are 4 models. Haven't printed any as the one's I printed are wall mounted, but they all look like they would work.
dunginhawk
thank you.. new thingiverse search is awful, didnt bring up any of these.
