I just purchased the Rift Headset and touch this weekend, and I am having trouble setting it up. I ran the program for setup and followed all the steps . Confirmed that everything was working as I went. At each step I waited for the green check to confirm it was connected correctly and received the green check and the message to continue. I got as far as to the part where it tells you to put on the head set and continue through the VR. When I put on my headset and continue I don't see anything in the headset just blank. Not sure what I am doing wrong as I am very new to this. This is my first attempt at anything like this. I am confused because I thought everything was connect correctly. Can some one help Thanks
