09-28-2022 10:53 AM
As you know, the guardian having to be reset is quite the frustrating thing. It's been an issue probably since the 20's-something version of Oculus Quest 2. No matter the lighting, etc, I would constantly lose the guardian. After searching the net I found a solution that works. Wish I could remember who posted it though.
When you create your guardian, cover one of the lower cameras on the headset. For me, I cover the lower left camera. While that is covered, create your guardian. It's odd at first because you can only see out of one camera. However, since doing this, I have rarely had a guardian issue. From what I read, it seems there could be a conflict between the cameras on the headset.
Anyway, hope this helps.
09-28-2022 12:09 PM
Clearing the guardian settings after an update seems to work for me.
09-28-2022 12:24 PM
I've tried that as well and it never worked for me. For some reason, covering one camera does the trick.
