06-10-2019 12:27 AM
05-06-2021 02:33 PM
So you're playing on Hard difficulty? Guess there's that Lightning Dog coming up soon, good luck with that/those 🙂
Oculus Rift CV1, Valve Index & PSVR2, Asus Strix OC RTX™ 3090, i9-10900K (5.3Ghz), 32GB 3200MHz, 16TB SSD
05-06-2021 02:44 PM
@RuneSR2 wrote:So you're playing on Hard difficulty? Guess there's that Lightning Dog coming up soon, good luck with that/those 🙂
Hmm would have to check but I think I am on normal difficulty.
05-06-2021 02:47 PM
Guess there's room for another playthrough then 😉 Did play a few levels on hard, didn't feel that much different, maybe there's just less ammo...
Did you try the C17YSCAPE?
05-06-2021 02:51 PM
@RuneSR2 wrote:Guess there's room for another playthrough then 😉 Did play a few levels on hard, didn't feel that much different, maybe there's just less ammo...
Not yet, will do that after I am done with this playthrough. Gives me something else to look forward to.
I wanted to see Alex in all it's glory with the Index, and it sure has not disappointed.
05-07-2021 02:32 AM
Plus you still got the A:HL Workshop stuff to try in the game,
05-07-2021 05:12 AM
Yeah I totally forget about that, guess I will have to also check it out here soon. Much goodness to be had in Alyx for sure.
05-08-2021 03:26 AM - edited 05-08-2021 03:30 AM
Figured I better check if the Index is working perfectly before removing the drives from the old rig - and it did install perfectly.
120+ Hz in res 200% worked perfectly (Steam also suggested that I used 120 instead of 90 Hz, again I really don't think Index was meant for 90 Hz), but haven't tried to push anything much yet. Surely this will be a game changer compared to 90 Hz. Seems like the RTX 3090 is an awesome match for the Index, although the GTX 1080 also worked great in most games - but using 90 Hz.
One small advice when setting up Index for the first time - especially when the Index has been set up before and base stations are in sleep mode - make sure base stations are running before trying to install the Index.
When you start to install SteamVR on a new rig with sleeping base stations, then SteamVR can't find them nor wake them up. I had to go to one very dark corner of the world to unplug one (corner behind my desk) 😬. Also nice to get some cables untangled... I guess...
Unplugging og re-plugging base stations will fully activate them - so that's why they don't remember the sleep mode 😉 I'd be in big trouble if they did 😉
05-08-2021 04:09 AM
An new Alyx map Pyromantic Gatekeeper is getting a lot of attention - rated just below C17YSCAPE - does look great, might try it later:
More here: https://steamcommunity.com/sharedfiles/filedetails/?id=2431703917
05-08-2021 05:24 AM
Even more goodness for Alyx, thanks for the heads up.
05-08-2021 07:45 AM - edited 05-08-2021 07:46 AM
@RuneSR2 wrote:(Steam also suggested that I used 120 instead of 90 Hz, again I really don't think Index was meant for 90 Hz), but haven't tried to push anything much yet. Surely this will be a game changer compared to 90 Hz.
Quest 2 supports 120Hz as well. Although, 120Hz isn't actually "changing the game" for any HMD. It's just getting reports of "smoother" visuals in specific situations (e.g. like rapidly swinging your arms).
The real "game changer" for Valve will be when they release their new Inside-Out tracking HMD. Until then, the game will remain unchanged as the only advantage is somewhat nicer colors and slightly smoother transitions.
