Tutorial: How to check fps inside Rift
iankemp
Didn't find anything here on this topic and FRAPS shows fps in the blind corners.
So step by step:
Use MSI Afterburner
http://event.msi.com/vga/afterburner/download.htm
Start it and go to Settings
There you can choose what you want to see besides Framerate in On Screen Display, so turn on 'in OSD'
In your System Tray you also have the RivaTunerStatisticsServer:
Use this settings and most important the coordinates on the lower right, I use 200 / 200
Edit: For FPS only you can use the RivaTunerStatisticsServer without MSI Afterburner:
http://www.guru3d.com/files-details/rtss-rivatuner-statistics-server-download.html
Set the coordinates to around 300x300 and switch on: Show own statistics
Thats it, on the upper left corner you will see your OSD. Note: In Direct HMD Access its showing double fps, so in DK2 you will need 150fps for judder free experience.
17 REPLIES 17
Godmademedoit
Excellent, I was wondering how to go about this to monitor performance. Thanks.
jrd3d
is that Far Cry 3 Blood Dragon? If so, is it running in the rift?
iankemp
With VorpX
cybereality
Level 15
Thanks for the guide.
Rubocop
Hooly mooly! Thank you! This is VERY important tool for oculus-divers!
Is there a place some where in this forum, where we can store such useful tips for oculus crowd? Would be sad if this info will lost in forum threads....
merire
Thank you, I'll try it asap. That is too bad that we don't have an FPS counter in every game/demo.
Christophe
Interesting. I suppose this would work for all Nvidia cards, even non-MSI ones, right?
iankemp
Yes, every manufacturer, even AMD Cards.
TrancerSpacey
Thank you!! Now I know definitively that my judder or stutter is a framerate issue and I will devinitively need a new PC. 😉
And yes, it works with my palit card too.
