05-21-2021 06:22 PM
CAN I USE MY OUCULUS QUEST 2 IN MY GARAGE
05-22-2021 12:17 AM
First of all, you might want to consider turning off caps lock.
Second of all, that entirely depends. Is your garage well lit with at least 6.5 feet by 6.5 feet of cleared space? Granted, you need less space if you set up a Stationary Guardian. But for Room Scale you need at least a 6.5 square foot area.
When not in use, you'd want to make absolutely sure you have a lens cover in place. Direct sunlight on the lenses is a bad thing.
05-22-2021 12:17 AM
Hi there! So long as your garage is well lit and there is minimal reflective surfaces and adequate room for you to move, it should be fine. You may need to reset your Guardian area however, and steps to do so can be found by clicking here. Thanks!
