Unofficial workaround for “access control list not in canonical form” error during Oculus Setup
cybereality
Level 16
There’s a known issue where the Oculus installer (OculusSetup.exe) may not successfully complete due to a Windows registry issue, and instead asks you to reboot your computer. You can identify whether this is the issue you’re having by opening %LOCALAPPDATA%\Oculus\OculusSetup.log and looking for the error message “This access control list is not in canonical form and therefore cannot be modified.”
We have a potential fix for this issue in the upcoming release, but in the meantime, the following unofficial workaround may work for you. Warning: this workaround requires that you edit your Windows registry!
1) Run regedit.exe
2) In the left tree view, right-click on HKEY_LOCAL_MACHINE, select "Permissions..."
3) If a dialog comes up stating that the permissions are incorrectly ordered, click "Reorder"
4) Click "OK" in the permissions dialog to close it
5) Repeat step 2-4 on any of the following tree nodes that exist:
- HKEY_LOCAL_MACHINE/SOFTWARE
- HKEY_LOCAL_MACHINE/SOFTWARE/Wow6432Node
- HKEY_LOCAL_MACHINE/SOFTWARE/Wow6432Node/Oculus VR, LLC
- HKEY_LOCAL_MACHINE/SOFTWARE/Wow6432Node/Oculus VR, LLC/Oculus
- HKEY_LOCAL_MACHINE/SOFTWARE/Wow6432Node/Oculus VR, LLC/Oculus/Config
After you make these changes, re-run OculusSetup.exe, and it should complete.
34 REPLIES 34
DarthAsad
I am having this install issue. Your remedy isn't working for me, I have tried it twice. Am I just opening the permissions and clicking OK with out modifying anything? I am also not seeing anything other than HKEY_LOCAL_MACHINE, is that normal? Any help is appreciated.
Thanks in advance.
cybereality
Level 16
You have to click the small arrow ">" on the left of the node name do pull out the tree. That's probably your issue. You may get a popup about reordering the permissions, which you should OK. If you don't see the popup, just click OK. Let me know if that helps.
DarthAsad
Thanks for the quick response, I got down to HKEY_LOCAL_MACHINE/SOFTWARE/Wow6432Node and do not see Oculus VR, LLC, only Microsoft.
P.S.: I did not get a reorder pop up fyi.
okedd6yai5i2.jpg Including screen shot for reference.
PKRipper
You are looking in the wrong place. you have HKEY_CURRENT_USER open and you need to be in HKEY_LOCAL_MACHINE
CPU: i7-4790k SSD: Samsung EVO 1TB SSD: PNY SSD240GB Graphics Card: GTX 1070 A bunch of parts that make the magic happen!
Popopinsel
Thanks cyber, worked like a charm!
DarthAsad
Thanks, worked after I went to the correct folder.
jjkramhoeft
thanks the fix worked for me
ColinB
Been away from the Forum for some time now.
Have a CV1 on order. Just wondering about these latest posts.
Are they about the CV1?
I thought that all this scripting and editing and regediting would have been finalised?
Is the CV1 "consumer ready" yet or is it still for developers at the moment?
I am not really a developer. Should I wait for the CV2 or risk it with the CV1?
StokedOn
"visual-cpp-2015.exe exited with code 1638" on Developer Machine With Visual Studio 2015 Update 2 RC installed.
