09-30-2022 08:38 AM
I can run the Oculus runtime fine from the PC, but when I connect using Remote Desktop the app isn't running and I can't start it.
I'm trying to get some openXR work done on my gaming PC from my office.
10-03-2022 04:11 AM
That's correct. An RDP session is isolated from the normal interactive user session that sees the real video card. Since OVRServer can't see an interactive session, it dies and you get a message in the Windows Application event log.
You may need to use a remote access application that runs within the interactive session, e.g. VNC. You might also need to find a way to activate your headset if that is needed for what you're trying to do.
