12-09-2016 03:06 PM
12-09-2016 03:15 PM
12-09-2016 03:21 PM
12-09-2016 03:23 PM
12-09-2016 03:33 PM
maxpare79 said:
Sure just buy a standard articulated 1/4 camera mount
Something like this
https://www.amazon.ca/HDE-Swivel-Bracket-Security-Camera/dp/B005H1W4LA/ref=sr_1_2?ie=UTF8&qid=148132...
12-09-2016 03:41 PM
bsselp said:
Also, will mounting the sensor upside down from the ceiling still work or will the sensor think you're upside down?
I have both mine mounted on the ceiling and they track correctly (No upside-down screen), and I didn't have to change anything in the settings for it to work.
Also both of my sensors are mounted more than 6 ft apart and still track very good - I've had no tracking problems, so far.
12-09-2016 05:22 PM
I did this yesterday to my two sensors....Rocketfish from best buy. You've got to put some thought into getting ones that'll get you the right angle as far as getting the sensors to point out from the wall given the articulation or lack there of the sensors have. It's an odd fit so again, give some thought to the mount you decide to go with to make sure it truly will serve your needs.
12-10-2016 09:03 AM
12-10-2016 10:37 AM
bsselp said:
That one looks good! Do you have the full name of the mount? I cant seem to find it on amazon.
12-10-2016 02:44 PM
ssahnan said:
