What's the difference between DK2 and Consumer Rift?
ScoutZR
I'll start this off by saying that I am super broke, but that I want to make my girl's birthday memorable.
Consumer Rift costs $400 while I can find a DK2 for $250.
Is there any real difference between the two? She literally only wants to play ONE game, Raw Data with multiplayer, so I need two sets.
I can save a lot of money by getting two DK2's... will Raw Data work on the DK2's? is there really any difference?
Also, will the DK2's also run on minimum specs?
Please help this budget gaming family.
13 REPLIES 13
Techy111
Volunteer Moderator
Volunteer Moderator
What are your pc specs ? Whilst you can get the dk2 running it has zero support now from Oculus. If you can then get a CV1. Also bear in mind you'll need 2 pc's to run 2 rifts and then 2 games.
ScoutZR
My computer is running at just barely the minimum new specs that Oculus released (I just need to get a little bit more RAM, waiting for my delivery), I'm buying used parts from eBay to upgrade it to meet these specs.
So it WILL run Raw Data?
Also, what do you mean by no support? Basically if something goes wrong, they won't fix it? I'm buying used, so I won't have a warranty anyway.
Techy111
Volunteer Moderator
Volunteer Moderator
Dk2 was the development kit so no, zero repairs and zero support. Cv1 is your best option with a 1060 or 970 card 16 gig of ram and a fairly good cpu plus loads of usb 3.0 slots or a usb hub.
cybereality
Level 16
You won't be able to play any games that use motion controls (most games out now) because Touch only works with the consumer Rift. Really, there is no reason to buy a DK2 at this point, not a good idea.
nosys70
well, you can get my DK2 for a lot less than 250$ with lot of options...
TwoHedWlf
Level 11
Yes, if something goes wrong there are no replacement parts.  It may suddenly stop working because they will not continue to ensure that new driver and software releases work with it.  Most new games cannot be guaranteed to work with it.  Touch controllers will not work with it.  The DK2 does not have a microphone or headphones.
The CV1 is fairly inexpensive and FAR better than the DK2, there is no good reason to actually pay money for a DK2.  (Unless you're a collector, then that's cool.)
cybereality
Level 16
Sorry, to be clear, Raw Data uses motions controls so won't work with DK2. You need Rift + Touch.
kojack
Volunteer Moderator
Volunteer Moderator
Support was only guaranteed until the end of 2016 if I remember correctly (it was a developer kit, not a consumer product, Oculus wouldn't want developers using outdated hardware to develop software). While the current Oculus environment still works on the DK2, support could be dropped at any time. Every time an update comes out (which you can't skip), there's a chance all DK2s will stop.
As to actual feature differences, the DK2 has:
- lower resolution (960x1080 per eye, vs 1080x1200 on the CV1)
- worse tracking (a single narrower view camera, vs 2-4 cameras on the CV1)
- no hand controllers
- no built in sound
- no microphone
- no 360 head tracking. The CV1 has tracking lights on the back of your head, the DK2 doesn't. Combined with only a single camera, that means turning away from the front with a DK2 means it can't track you.
The hand controller part is the biggest problem. A lot of Oculus software now requires Touch controllers, but it is physically impossible to use them with a DK2 (it doesn't have the wireless hardware inside that Touch needs).
The DK2 is certainly cheaper as a VR headset, but it may also become a very expensive paperweight as less software is usable (due to lack of hand controllers) and the Oculus runtime may drop it.
DaftnDirect
Volunteer Moderator
Volunteer Moderator
I wouldn't sell my DK2 to anyone now, not just because it belongs in my personal little museum of tech,
….but because in all good conscience, I couldn't recommend anyone actually buy it.
Intel 5820K OC@4Ghz, Titan X (Maxwell), 32GB Corsair Vengeance DDR4, ASRock X99 Taichi, Samsung 500Gb 960 Evo M.2, Corsair H100i v2 Cooler, Inateck KTU3FR-4P USB 3 card, Windows 10 Pro v20H2 (19043.1081)
