Where to find a oculus rift cv1 face pad replacement??
legaiaflame
Hi I need an oculus rift cv1 face pad replacement?? Are any of the Oculus go ones compadible with CV1? Anyone have any suggestions?
4 REPLIES 4
OmegaM4N
Level 11
Only the Cv1 will fit it, but on amazon and ebay you can buy the faceial interface and foam cover in one, then you can just buy new foam covers separately after than. 😉
CV1/Vive-knuckles)/Dell Vr Visor/Go/Quest II/ PSVR.
Can you link me to what you are talking about?
@legaiaflame  this is the one I bought for my Rift cv1.  Works very well for me.
https://www.amazon.com.au/AMVR-Facial-Interface-Comfort-Oculus/dp/B07VK767B4/ref=sr_1_4?crid=3DDZ4X8...
Maybe try searching your local amazon store - Oculus Rift cv1 facial interface.
legaiaflame
Thanks found it. Really appreciate it!
