Yet another Rift S vs Quest, Max IPD?
Ryanteck
Honored Guest
So I'm trying to decide between the Rift S or Quest as an upgrade from my WMR headset.
My main use is PC gaming, even if I had the quest I'd say around 90% would be on PC using link. From most reviews I've seen most people say still get the Rift S for this reason (I play beatsaber the most etc).
However my main concern is my IPD is 70-71 (according to my last prescription it was 71, I measured around 70 but one previous prescription also has 68) and from what I've seen a lot of people seem to say 66 is the most for the Rift S.
I would then usually dismiss the Rift S however my WMR headset is also a fixed IPD with a software adjustment to 67MM it seems mostly fine to me.
Does anyone here use the Rift S with a high IPD?
0 REPLIES 0
