11-20-2019 08:44 PM
11-20-2019 09:16 PM
The Anchor cable that Oculus has linked to is 3m (10 ft), not 2m (6 ft).
Lunatic_Fringe said:
Oculus is recommending the Anchor cable for use with the Quest until the link cable is released. The cable is only 6 feet. Has anyone tried to connect them to make a longer cable..Does it work?
11-20-2019 09:24 PM
11-20-2019 09:32 PM
The active usb extension cable that came with my extra cv1 sensor is usb 2.0, not 3.0.
nalex66 said:
3m/10' is about the limit for a passive cable. You need active cables to go longer than that; I used my 5m/16' active extension cable from my CV1 sensor along with a 1m/3' A to C Anker cable, and that worked fine.
11-20-2019 09:39 PM
11-20-2019 09:57 PM
No, I just double checked the one that I bought from the Oculus Store with an extra sensor. It is Active usb 2.0.
nalex66 said:
No, the USB 3.0 active extension cable that I bought to use with my sensors. The cable that comes with the extra sensor is passive, as well as USB 2.0.
11-21-2019 12:15 AM
11-21-2019 04:34 AM
Spuzzum said:
I'm not so sure on the 3M limit...the Rift-S uses a 5M cable, and the Rift CV1 is 4M, and both are passive. I think 5M is about as far as you can take it though.
11-23-2019 12:49 AM
nalex66 said:
I’m pretty sure the CV1 cable has a chip to boost the signal in the “special connector” end I extend my CV1 with an extra 2m of passive cable, which would be a pretty long passive cable length.
