inateck usb 3.0 expansion card drivers
god_alom
So I've installed the inateck usb 3.0 expansion card, but don't know what driver to install. I've getting the computer ready for touch. But what drivers do I install, red for fresco or green for nec, or do an online update?
20 REPLIES 20
goldenegg
Level 7
Just use the Windows drivers.  Oculus Home will tell you to update the drivers, but just ignore that.  The drivers on their site have a bunch of weird issues.
god_alom
ok cheers
god_alom
ok so I'm not sure if I've installed it properly but none of my usb devices are being recognized.
goldenegg
Level 7
Did you connect the power cable to the card? Also, what version of Windows are you running?
god_alom
Windows 10
goldenegg
Level 7
You don't need any special drivers for Windows 10.  Just make sure you've connected the internal power cable for the Inateck card.  It won't work without it.
god_alom
Is it the pci expansion slot above the graphics or below?
cybereality
Level 15
The latest driver, 3.6.8.0, should be best.
https://support.zoho.com/portal/frescologic/home
goldenegg
Level 7
It doesn't matter which PCI-E slot you plug the card in to.  Regardless of the slot, you still need to connect a power cable to the card.  Have you done that?
