oculus has detected a hardware
maguilla86
oculus has detected a hardware issue that preventing you  from setting up your rift. Please check that your headset connected and all cable ends are firmly seated. if you'are still having trouble, you can also selecr try again tp repeat  the setup process
3 REPLIES 3
Hiro_Protag0nist
Level 13
Have you checked the cables going to the Rift itself?
Is the HDMI cable connected to the graphics card?
Have you gone to settings or devices in Oculus Home and looked at any messages there (if you can)?
I'd raise a support ticket whilst you are trying to get things working.
Is it new?  What PC/laptop is it?  Specs?
maguilla86
maguilla86
yes
yes
laptop    11377 NB ACER GAMING PREDATOR G3-571-77QK 17-7700HQ 2.8GHZ/16GB/SSD M 2 S56GB/15.6 FHD IPS/VGA GTX 1060 6GB/ W10/INGLES
