04-30-2021 01:30 PM
Hello, i experienced the searching forever for computer problem with air link, i have 2 routers, and the second router is connected via wan, dhcp is on in all 2 routers, with this configuration airlink can't find my computer (can find only the first router that i use as a adsl modem)
i found a "solution" by disabling dhcp on second router and connecting all in lan. The fact is that virtual desktop streaming work perfect in lan/wan confitgurations, but airlink work only in lan, why?
i prefer keep the second router in wan, is possible for oculus fix this problem for make visible the pc in all situations lan or wan? thanks for help
