No HMD detected - On extend Desktop
Mbreis
Honored Guest
When I Choose extend to desktop to the hmd everything works fine, the oculus screen turns on, the resolution is set. But on the configuration utility it says that there is "NO HMD DETECTED, Tracker Connected" and the games also do not recognize that there is a HMD, so I am not being able to utilize the rift. I am using the DK2, i have already updated all of my softwares and I have already reinstalled the oculus utility and drivers and still nothing. I have also switched usb drives from 2.0 to 3.0, turned the headset on and off and still nothing. I am considering formating my pc which is currently 8.1 to maybe windows 7. If anyone can help at all I will be very thankful.
39 REPLIES 39
cybereality
Grand Champion
Can you list your OS version, system specs, and GPU driver version?
Also, go in the Config Util and save a debug log from the Tools/Advanced menu.
Mbreis
Honored Guest
Mbreis
Honored Guest
Hi Cybereality, thanks for the help! I should also state that in Direct HMD works just fine, it recognizes the oculus, only when i switch it to extended that it stops.
Here is the information, if you need anything else let me know ! thanks agian!
System:
Intel Core i7 - 4700 hq CPU 2.40ghz
24gb ram
Windows 8.1
Nvidia Geforce GTX 780m 4gb
Driver version 347.88
Debug:
"Time": "2015-04-12_21:14:53",
"SDK Version": "0.5.0.1",
"Service Protocol": {
"Major": 1,
"Minor": 3,
"Patch": 0
"RemoteProtocolVersion": {
"Major": 1,
"Minor": 3,
"Patch": 0
"Service Running Time": {
"Hours": 2,
"Minutes": 24,
"Seconds": 37
"System Specifications": {
"Operating System": "Microsoft Windows 8.1",
"Processor": "Intel(R) Core(TM) i7-4700HQ CPU @ 2.40GHz",
"Graphics Adapters": [{
"Name": "NVIDIA GeForce GTX 780M",
"Video Controller RAM (MB)": 4095,
"Driver Version": "9.18.13.4788",
"Video Mode": "1920 x 1080 x 4294967296 colors"
"Total RAM (GB)": 24,
"USB Tree": [{
"name": "Intel(R) 8 Series/C220 Series USB EHCI #1 - 8C26",
"deviceid": "PCI\\VEN_8086&DEV_8C26&SUBSYS_201F1043&REV_04\\3&11583659&0&E8",
"caption": "Intel(R) 8 Series/C220 Series USB EHCI #1 - 8C26",
"manufacturer": "Intel",
"Devices": [{
"manufacturer": "(Standard USB Host Controller)",
"name": "USB Root Hub"
"manufacturer": "(Generic USB Hub)",
"name": "Generic USB Hub"
"name": "Intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D",
"deviceid": "PCI\\VEN_8086&DEV_8C2D&SUBSYS_201F1043&REV_04\\3&11583659&0&D0",
"caption": "Intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D",
"Devices": [{
"name": "Intel(R) USB 3.0 eXtensible Host Controller - 0100 (Microsoft)",
"deviceid": "PCI\\VEN_8086&DEV_8C31&SUBSYS_201F1043&REV_04\\3&11583659&0&A0",
"caption": "Intel(R) USB 3.0 eXtensible Host Controller - 0100 (Microsoft)",
"manufacturer": "Generic USB xHCI Host Controller",
"Devices": [{
"manufacturer": "(Standard USB HUBs)",
"name": "USB Root Hub (xHCI)"
"name": "USB Composite Device"
"manufacturer": "Microsoft",
"name": "USB2.0 UVC HD Webcam"
"manufacturer": "Qualcomm Atheros Communications",
"name": "Qualcomm Atheros AR3012 Bluetooth 4.0"
"name": "Microsoft Bluetooth LE Enumerator"
"name": "Bluetooth Device (RFCOMM Protocol TDI)"
"name": "Microsoft Bluetooth Enumerator"
"name": "Bluetooth OPP"
"name": "Bluetooth A2DP Source"
"name": "Bluetooth A2DP Sink"
"name": "Bluetooth AV Remote Control Target"
"name": "Bluetooth Advanced Remote Control Service"
"name": "Bluetooth HeadSet Audio Gateway"
"name": "Bluetooth PANU service"
"name": "Bluetooth NAP service"
"name": "Bluetooth Handsfree Audio Gateway"
"name": "Bluetooth Sim Access Service"
"name": "Bluetooth Phone Book Access"
"name": "Bluetooth Message Access Profile Server"
"name": "Bluetooth Generic Access Profile"
"name": "Bluetooth Generic Attribute Profile"
"name": "Bluetooth AVRCP Device"
"name": "HID-compliant consumer control device"
"name": "Bluetooth Audio Device"
"name": "Bluetooth Hard Copy Cable Replacement Server"
"name": "Virtual Bluetooth Support (Include Audio)"
"name": "Bluetooth LWFLT Device"
"name": "HMDX JAM"
"name": "Galaxy S5"
"name": "Bluetooth Device (Personal Area Network)"
"name": "Microsoft Mouse and Keyboard Detection Driver (USB)"
"manufacturer": "(Standard system devices)",
"name": "USB Input Device"
"manufacturer": "(Standard keyboards)",
"name": "HID Keyboard Device"
"name": "Microsoft Hardware USB Mouse"
"name": "Microsoft USB Wireless Mouse (Mouse and Keyboard Center)"
"name": "HID-compliant vendor-defined device"
"name": "HID-compliant system controller"
"Drivers": [{
"Path": "\\system32\\OVRDisplay64.dll",
"Version": "1.2.4.0"
"Path": "\\system32\\OVRDisplayRT64.dll",
"Path": "\\syswow64\\OVRDisplay32.dll",
"Path": "\\syswow64\\OVRDisplayRT32.dll",
"Path": "\\system32\\drivers\\RiftEnabler.sys",
"Path": "\\system32\\OVRDisplay32.dll",
"Path": "\\system32\\OVRDisplayRT32.dll",
"Path": "\\system32\\drivers\\OCUSBVID.sys",
"Version": "1.0.9.0"
"Video Device Tree": [{
"VRAM (MB)": 3072,
"Monitors": [{
"Name": "\\\\.\\DISPLAY1",
"Width": 1920,
"Height": 1080,
"Refresh Rate": 60
"Name": "Microsoft Basic Render Driver",
"VRAM (MB)": 0,
"Monitors": []
"Devices": []
DonkyBoY
Protege
Exact same problem with 5.0.1 was working fine with 0.4.4
In extended desktop "NO HMD Connected" in the Oculus config but in direct to HMD it works fine
Windows 7 x64
Nvidia 347.88
i7 4790K @4.4GHz / Asus Z97 Deluxe / 2 MSI GTX970 4GB in SLI / 32GB DDR3 @2400Mhz
Turning the Rift off and on again doesn't help 😞 but just incase I tried restarting the Oculus service as well no dice
Here is my debug info
"Time": "2015-04-14_06:24:18",
"Major": 1,
"Minor": 3,
"Patch": 0
"Major": 1,
"Minor": 3,
"Patch": 0
"Hours": 0,
"Minutes": 12,
"Seconds": 27
"Operating System": "Microsoft Windows 7 Ultimate ",
"Processor": "Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz",
"Name": "NVIDIA GeForce GTX 970",
"Video Mode": "1440 x 900 x 4294967296 colors"
"Video Mode": "1080 x 1920 x 4294967296 colors"
"Total RAM (GB)": 32,
"USB Tree": [{
"name": "ASMedia XHCI 1.0 Controller",
"deviceid": "PCI\\VEN_1B21&DEV_1142&SUBSYS_85FD1043&REV_00\\4&22B4BC25&0&00E6",
"caption": "ASMedia XHCI 1.0 Controller",
"manufacturer": "ASMedia Technology Inc",
"Devices": [{
"name": "HID-compliant device"
"manufacturer": "Oculus VR",
"name": "Oculus Video Camera"
"name": "Standard Enhanced PCI to USB Host Controller",
"deviceid": "PCI\\VEN_8086&DEV_8CA6&SUBSYS_85341043&REV_00\\3&11583659&0&E8",
"caption": "Standard Enhanced PCI to USB Host Controller",
"Devices": [{
"deviceid": "PCI\\VEN_8086&DEV_8CAD&SUBSYS_85341043&REV_00\\3&11583659&0&D0",
"Devices": [{
"name": "Intel(R) USB 3.0 eXtensible Host Controller",
"deviceid": "PCI\\VEN_8086&DEV_8CB1&SUBSYS_85341043&REV_00\\3&11583659&0&A0",
"caption": "Intel(R) USB 3.0 eXtensible Host Controller",
"manufacturer": "Intel(R) Corporation",
"Devices": [{
"name": "Intel(R) USB 3.0 Root Hub"
"name": "USB 2.0 MTT Hub"
"manufacturer": "Broadcom",
"name": "Bluetooth USB module"
"name": "Standard Serial over Bluetooth link (COM5)"
"name": "Standard Serial over Bluetooth link (COM3)"
"manufacturer": "Standard Cell Phones",
"name": "Standard Modem over Bluetooth link"
"name": "Bluetooth Hands-free Audio"
"manufacturer": "Broadcom Corp.",
"name": "Bluetooth L2CAP Interface"
"name": "Bluetooth Remote Control"
"manufacturer": "Corsair",
"name": "Corsair Vengeance 2100 Headset"
"manufacturer": "Logitech",
"name": "Logitech Cordless Gaming Receiver"
"manufacturer": "Logitech Cordless Gaming Receiver",
"name": "Logitech Gaming HID Device"
"name": "USB 2.0 Hub"
"name": "Logitech G700s Rechargeable Gaming Mouse"
"manufacturer": "Logitech G700s Rechargeable Gaming Mouse",
"manufacturer": "Razer Inc",
"name": "Nostromo Input Device"
"name": "Razer Nostromo"
"manufacturer": "Razer",
"name": "HID-compliant game controller"
"manufacturer": "Saitek",
"name": "Saitek X52 Flight Controller (USB)"
"name": "Saitek X52 Flight Controller (HID)"
"name": "HID-compliant mouse"
"name": "USB 3.0 Hub"
"manufacturer": "Cyber Power Systems, Inc.",
"name": "CyberPower Battery Backup"
"Drivers": [{
"VRAM (MB)": 3072,
"Monitors": [{
"Name": "\\\\.\\DISPLAY2",
"Width": 1920,
"Height": 1080,
"Refresh Rate": 75
"Width": 1440,
"Height": 900,
"Refresh Rate": 60
"Devices": [],
"Profile": {
"Player Name": "DonkyBoY",
"IPD": 0.066386,
"Eye height": 1.725472,
"Eye Cup": "",
"Eye Relief": 3,
"Gender": "Male",
"Eye To Neck": 0.075000,
"Player Height": 1.828800
So after a few hours messing about I couldn't find a solution so I reverted back to the older 0.4.4 runtime and like magic it works again.
Strange that some users report better experiences with the newer 0.5.0.1 runtimes but it fails to work or even detect the hardware for others.
Any help with this one would be appreciated thank you for reading and I hope the information is useful to someone.
Oculus CV1 room scale with 3 tracker's
i7 4790K @ 4.4Ghz with delid and Liquid metal ultra +Corsair H110i / MSI GTX1080Ti Sea Hawk / 32GB DDR3 @2400Mhz
(All rads running EK Furious Vardar F4 / F5 fans)
Sandisk Extreme for OS and Kingston SSD Now for games
Steam = http://steamcommunity.com/id/xgsdonkyboy
TS3 server = xgs.ts3.nz
cybereality
Grand Champion
I have filed a bug report and people are looking into this now.
Lhun
Explorer
Windows 7 x64
Nvidia 347.88
"Major": 1,
"Minor": 3,
"Patch": 0
"Major": 1,
"Minor": 3,
"Patch": 0
"Hours": 0,
"Minutes": 12,
"Seconds": 27
"USB Tree": [{
"Devices": [{
"Devices": [{
"Devices": [{
"Devices": [{
"Drivers": [{
"VRAM (MB)": 3072,
"Monitors": [{
"Width": 1920,
"Height": 1080,
"Refresh Rate": 75
"Width": 1440,
"Height": 900,
"Refresh Rate": 60
"Devices": [],
"Profile": {
"IPD": 0.066386,
"Eye Cup": "",
"Eye Relief": 3,
"Gender": "Male",
Can you make sure your video card outputs are not using shared ports? Annnnd that you connect the rift on your primary card?
I find that running the rift in extended mode only works fully properly if you're using non-shared outputs from the display adapter.
DonkyBoY
Protege
@ Lhun
The Rift is connected via the primary card and using the HDMI connector on the card with no adapters of any kind.
I also tried with the USB in other ports both USB3 and 2.
I even have tried a powered hub for the USB but no joy.
My main screen is connected via the primary card using the bottom DVI-D connector
With a TV Screen connected the top DVI connector again on the primary card (but when I use the Rift I disconnect the TV)
I have also tried reinstalling the current VGA driver
If you guys need any more information on my system I am happy to run what ever you need to get any answers you need.
cybereality
Grand Champion
Are you guys (by any chance) using TeamViewer or any other type of remote desktop / screen sharing apps?
DonkyBoY
Protege
Nothing like that here.
