11-12-2022 09:04 AM
Hello everyone.
As the title says, i have massive performance issues with VR right now.
Even on the Oculus dash screen, it is stuttering so bad, that i can't use VR in any way, most noticable when i move my head around.
My Hardware is an AMD R7 5800x, RTX3080, 32GB Ram @ 3600MHz
It worked perfectly fine a month or so ago
I did some research and some people say, it is caused by the 22H2 Update of windows 11, is that the case?
and if so, is there a workaround?
Here is a screenshot of fpsVR, maybe it helps.
Thank you in advance.
11-12-2022 12:52 PM
My CV1 is working flawlessly - I'm using RTX 3090 and Win10 Pro - driver 512.15.
Oculus Rift CV1, Valve Index & PSVR2, Asus Strix OC RTX™ 3090, i9-10900K (5.3Ghz), 32GB 3200MHz, 16TB SSD
11-15-2022 10:49 AM
Hello there @Alfisonson! You said you updated your Windows 10, which may be an issue. We suggest you gather your PC logs and send them to our support team and we can dig deeper into this issue for you. Don't send the logs to the forums as we don't want your information being leaked out.
12-03-2022 07:45 PM
Hello and thank you for your replies.
I just got the Update KB5020044 from microsoft Update and now everything is smooth again and is running like a charm.
By that, I call the Problem solved.
Again, thank you for your replies.
