Rift Crackling Audio
simonjkendrew
Explorer
I’ve been using an Oculus Rift on my PC for almost 18 months
without any audio problems, but as of about 5-6 weeks ago, the audio through my
rift headphones (both left and right) has a crackling sound, which is becoming
very annoying and a little disorientating when using the headset. I’ve read
other forum posts of similar issues and have tried various advice from other
people, but cannot seem to resolve the issue.
The crackling sound only happens through the rift
headphones, my attached PC speakers or other headphones are OK. The crackling sound does not appear to be related to
specific games or applications, because it also happens if I play a test sound in
the Windows Sound > Playback > Rift Audio Headphones applet. The
crackling can sometimes be really bad, and other times not so bad. There are
some occasions where the crackling doesn’t happen at all and the sound plays fine,
although this doesn’t happen very often; the majority of the time there is a
crackling sound on the audio.
For the first 18 months before the problem started, the Rift
USB cable was connected directly to one of the rear motherboard USB3 sockets
(no extension cables). I haven’t changed the hardware in my PC prior to
this problem starting.
I’ve tried the following advice I’ve seen on other posts,
but none of these have solved the problem:
PC Spec
  • Win 10 Pro (64 bit) Version 1803 (build 17134.81)
  • i7-6700K, overclocked to 4.5GHz (done by manufacturer)
  • ASUS Z170 Pro Gaming Motherboard
  • 16GB
  • 2 x 500GB SSD
  • EVGA GeForce GTX 1080
    8GB
RIFT Setup
  • Oculus app version 1.26.0.582280
  • 3 x Rift sensors (2 connected to motherboard
    rear USB 3.0 sockets, 1 connected to motherboard rear USB 2.0 socket (using the
    USB2.0 extension cable supplied by oculus)
Any help in solving this would be greatly appreciated.
44 REPLIES 44
sheuho
Explorer
I just assume it was the 1.29 update as that was the last thing I install on may system. I don't download on of the internet, just via Steam and Oculus. I did read that anything behind 3m extension cable can cause issues, but since you've been using it for over year then something is a mis here and I can't figure it out as its ruining my Rift experience.
Morgrum
Expert Trustee
I am also starting to see this over the past few weeks.
Clackeling in both and sound cuts out entirely in Marvel.
I'll try what kojack said.
ElusiveMarlin
Rising Star
It is rather spoiling my experience too to be honest.
It is still hit and miss though, so when it happens, I reboot my PC and 8 times out of 10 it goes away, but then who knows if it will return on the next boot!
RIFT CV1
RIFT S
Leeds, UK.
Morgrum
Expert Trustee
My issues I know for a fact started with the update a few weeks back.
kojack
MVP
MVP
Yep, mine started around the same time everybody else's did. A bit too coincidental for all of us to suddenly get hardware failures at the same time.
cybereality
Grand Champion
If you're having an audio issues with the latest update, please contact us for assistance.
https://support.oculus.com/
You can also upload your LogGatherer zip file so I can take a look. Thanks.
https://forums.oculusvr.com/community/discussion/33792/how-to-get-logs-for-bug-reports-for-consumer-...
ElusiveMarlin
Rising Star
Just ran the debug tool
As a side note, I now seem to be the victim of loosing audio in the left earpiece! 😞
Here is my log gather bundle
RIFT CV1
RIFT S
Leeds, UK.
ElusiveMarlin
Rising Star
I have also opened a support ticket as suggested @cybereality.
Support ticket #587334
Thanks
RIFT CV1
RIFT S
Leeds, UK.
cybereality
Grand Champion
I'm speaking with the team about this now. Thanks for bringing it to my attention.
ElusiveMarlin
Rising Star
Thank you @cybereality, Appreciate your help on this.
RIFT CV1
RIFT S
Leeds, UK.
