11-19-2022 01:36 PM
Our oculus has been stuck on the spinning Meta logo for about two weeks now. We have looked up youtube videos, tried the soft reset, logged in to meta account online, and made sure it was charged. It was stuck on red, then stuck on orange 'while charging', and now it is stuck on white and the meta symbol is still stuck spinning. Where should I go from here? @
11-19-2022 03:09 PM
Hey Doomed.2022, thanks for being proactive and trying out some things. We understand this can be frustrating as it stops anything from happening. Let's try a factory reset. Here are the steps:
Keep us updated on your progress!
11-20-2022 01:22 AM
I wiIl follow up. Thank you.
11-20-2022 01:22 PM
If I do the factory reset will I lose all my games again?
11-20-2022 01:25 PM
Should we run any updates?
11-20-2022 01:57 PM
We logged into the app on our phone and dont see any of our games. We've tried to create a meta cloud account and don't see any of our games either.
11-21-2022 01:04 PM
Hey @Anonymous, when performing a Factory Reset it will remove your games from the headset. However, if you have not done so yet you can active the Cloud Backup system beforehand to save your data.
Please do the following steps to check if your Cloud Backup is on:
• Put on your headset, then hover over the clock on the left side of the universal menu. When Quick Settings appears, select it to open the Quick Settings panel.
• Select Settings
• Select System, then select Backup.
• Select the toggle next to Cloud Backup to turn Cloud Backup on or off.
You can also click here to see the steps and once you have done this you can freely perform the Factory Reset. Please PM us know if you have any further question, we'd be happy to answer them!
Please select our name to get to our profile page, or click here. Next, click "Send a Message" to privately message us! Please remember, you must be signed into the community first to send us a private message.
11-22-2022 09:22 PM - edited 11-22-2022 09:24 PM
Thank you so much! Going to try that and we will let you know!
11-24-2022 11:25 AM
Hey again! We are just checking to see if you are having any troubles with your device. We look forward to your update and getting you back into VR!
11-27-2022 08:47 AM
We have been unable to make a cloud account so we can preform the factory reset. Whenever we try to create the username Doomed.2022 it says it is an invalid format. How do we go about getting the Meta cloud set up ?
