Measuring Loudness on Gear VR
DavidTurpinMagn
Honored Guest
When using the Oculus Audio Loundess Meter for Gear VR, what level should I set my Windows playback device to?
According to the documentation, I should set the Gear VR volume to 100% and the Windows mixer line-in level to 100%. Check and check. The problem is that there's also the Windows playback device, which is what the Loudness Meter actually listens to, and it has its OWN volume. This volume setting completely affects the final levels that the Loudness Meter measures, so it's critical to know what to set it to.
I'm on Windows 10, if that makes a difference.
0 REPLIES 0
