Can anyone help with a phone set up issue
tomflemons
I have bought a cheap phone running Android Marshmallow as a gift to help someone link their Go headset but it is seems to drop every time. The phone seems OK otherwise. I use Apple myself so have no experience of Android. Should I just ditch the phone and find a better one or is these anything I can do? Any help would be appreciated.
3 REPLIES 3
Techy111
Volunteer Moderator
Volunteer Moderator
Marshmallow should do it ok but it is the lowest min required =
https://support.oculus.com/674083216048783/
Anonymous
Not applicable
You can get a used iPhone in like new condition on amazon for $100.
JohnnyDioxin
Level 11
$100 just to register a Go 😄
i5 9600k @4.5GHz; 16GB DDR4 3200; 6xSSD; RTX2080ti; Gigabyte Z390D Mobo
Rift CV1; Index; Quest; Quest 2
