What features would you suggest for an Oculus Go Kiosk mode?
voxelmaniam
FieldOfVision would like it to be possible to put the Go into a Kiosk mode, as in to only play a single application automatically upon turning on the device.
How should it be configured?
Should it be password protected?
What are your thoughts?
A voxel is a three dimensional pixel!
Murray Foster
25 REPLIES 25
MSQTobi
There are mulitple ways to go for this:
- Customize the oculus home, to only show the launch button for specific apps and very basic setting like volume and brightness
- Require password to leave current app and return to oculus home
- Auto launch into an application on start up, and only allow restarting the app, but not leaving.
For me personally it doens't how it it implemented. I simply need to restrict user (especially ones that are nor familiar with the hardware) from doing things that require staff to "fix" the device after using it
Woolax
For me, what I need is:
- Auto-launch app when booting
- Being able to launch another apps, and then return to kiosk app
- Limit the settings the user can access to
- Exit of kiosk mode through password
Flrnhbr
Kiosk mode should:
  • Lock the running App
  • Not return to Oculus Home by home button
  • Not poweroff by powerbutton
  • Ask for leaving the App by pressing the Power-Button
  • Be Password protected or not
undef_dev
as long as we can set the own app as launcher with adb and then the device directly boots into it, i only need to have the option to disable the "Enter VR" welcome screen.
FieldOfVision
Level 7
I agree with the above. The ability to set the device in a single app mode without any way to get to the Oculus home page. Additional elements on this are a bonus, such a password protection and any other prompts.
Latest VR game: Crazy Kung Fu
Other games: www.FieldOf.Vision
justiceinc
I need really only two settings for kiosk mode:
- launch a single app when the user turns it on (can also be turned off by the user)
- Home button can be remapped to not go to Oculus home, but perform other feature, like Help menu
Then I will buy a large amount of Oculus Go systems (or whatever VR system delivers this essential feature)
lord_of_shred
I need:
- Possibility to load a specified application after the device is turned on
- Disable methods for the home button
I'd love to have:
- A watchdog service that checks if the specified application is still running, if not to restart it
voxelmaniam
I need:
I'd love to have:
Add to this: Configuration of the kiosk mode from a USB drive that is configured to install on boot for fast stand alone setup.
Murray Foster
Luzido
just wanted to say that a kiosk mode is really needed and would be awesome. thanks 🙂
